ᐅ Interior Sound Insulation: Drywall Construction vs. Solid Construction
Created on: 6 Jan 2017 10:09
Torsten-HBST
Torsten-HBS6 Jan 2017 10:09Hello,
we are planning the construction of a new detached house (1.5 stories) using solid construction methods. Now that the floor plan is mostly finalized, I noticed today that the interior walls in the attic are shown as drywall partitions on the plan.
So far, I had assumed all walls would be solidly built, as stated in the construction description. Now my question is: does a well-insulated drywall partition provide the same sound insulation to the adjacent room as a masonry wall?
I would prefer to avoid the children waking up because we are watching TV in the bedroom or someone is taking a shower in the bathroom.
Can anyone provide some insight on this?
Torsten
Torsten
Knallkörper6 Jan 2017 14:55Torsten-HBS schrieb:
Does a well-insulated drywall provide the same sound insulation to the neighboring room as a masonry wall?No, not economically. A drywall that achieves the same sound insulation values as a brick wall would be significantly more expensive and thicker than the brick wall. But precisely for cost reasons, drywall partitions are planned by your provider 😉
BungaSeppel20 Jan 2023 11:32Hello everyone. It has been 6 years since this response, and technology may have advanced since then. So I’m bringing this up again.
We want to install a partition wall that, in the final stage of development, will separate a children's bedroom from the living/dining area. There are many options: drywall with a focus on sound insulation, bricks, or a timber stud exterior wall (since part of the house may be extended with a timber stud wall, it might be possible to continue the exterior wall here directly).
What is currently the best solution for this? Until now, I assumed drywall is the ultimate option because of the cavity in the middle, at least if the focus is on soundproofing, but this thread has made me uncertain.
And I have a follow-up question: should the screed be additionally grooved/decoupled here? Or is this irrelevant for soundproofing within the same residential unit?
You can add weight by installing a second layer of gypsum fiberboard. For decoupling, there are special rails available.
I imagine you could also use something heavier than mineral wool insulation in the cavity (wood fiber, loose fill?), but I don’t have enough experience with that.
