ᐅ Incorrect installation boxes used. Who is responsible for the resulting costs?
Created on: 5 Jan 2020 17:35
lin0r87
lin0r875 Jan 2020 17:35
we have the following problem...
We ordered 19 recessed ceiling spotlights in the prefabricated ceiling on the ground floor from the shell construction company. We want to control everything via DALI.
One spotlight was charged at €83. This price included the housings and the installation.
Now to the problem...
THE COMPLETELY WRONG HOUSINGS (Kaiser 1227-55) WERE INSTALLED!
One housing alone costs €2.14! The diameter is 60mm (2.4 inches).
Diagonal wooden beam on steel frame over concrete construction site; background with construction equipment.
I could not fit any spotlights into these housings, so I said, "Remove the ceilings and redo them!"
This was not done. The ceilings were simply laid on top. I had no say in this, for whatever reason.
The shell constructor promised to find a solution. I agreed, on the condition that the full price would definitely not be paid!
A core drill hole of 170mm (6.7 inches) was made, and the correct housings were inserted and somehow adjusted (??)...
Complete mess! On top of that, the openings for the “new” housings were terribly modified. They want me (a layperson) to close the gaps.
The spots are partly misaligned and not flush with the ceiling surface as they should have been at the factory.
Round PVC pipe in a concrete floor opening, tape measure shows diameter of the hole.
Construction site with steel reinforcement, pipes and insulation material on a concrete foundation slab.
To somehow ensure alignment, I bought new front covers (about €6 each) to at least achieve a decent result.
Two round components: upper gray speaker cover with perforated pattern, lower smooth metal plate.
The point is, they insist on the full amount, saying they did not earn anything and actually lost money.
The fault clearly lies with the shell constructor.
How would you handle such a situation? Would a 50-60% deduction be reasonable, or would you say a full 100% deduction is justified?
I really need advice on this matter.
Vicky Pedia5 Jan 2020 18:05
Do you have a general contractor or is the project managed through separate contracts? Do the plans clearly indicate the installation boxes to be installed without any doubt?
lin0r875 Jan 2020 18:47
Vicky Pedia schrieb:
Do you have a general contractor or is it a direct contract? Was it clear from the plans which recessed lighting housings needed to be installed?
This was done under direct contract. Based on the spot lighting plan provided by the architect, the diameter of the spots was known, and the housings were to be selected accordingly.
guckuck2
5 Jan 2020 18:50
So they are not specifically listed in the scope of work?
Are they documented in writing anywhere else?
At least the required diameter, or whether with or without a tunnel?
lin0r875 Jan 2020 18:53
guckuck2 schrieb:
So, are they not specifically listed in the scope of work?
Is there any written confirmation at all?
At least regarding which diameter is required, or whether it should be with or without a tunnel?
This was communicated verbally. It was a small mistake on my part not to document it.
It was discussed with the general contractor (project management) and then passed on to the structural builder.
seat885 Jan 2020 18:56
lin0r87 schrieb:
This was done verbally. That was a small mistake on my part not to document it.
Then you have already admitted fault yourself. Verbal agreements are worthless. You will have to bear the loss yourself.
