V
VolkerRacho8226 Mar 2025 17:15Hello everyone,
I am planning to buy an awning that is 4m wide and extends 3.50m (11.5 feet). The problem is that I can only install it up to a maximum height of 2.50m (8.2 feet) on the wall. With a 9-degree incline, this would result in a clearance height of 1.95m (6.4 feet). However, a minimum inclination angle of 15 degrees is usually recommended.
What are your experiences?
Best regards, Volker
nordanney26 Mar 2025 17:23VolkerRacho82 schrieb:
A minimum slope angle of 15 degrees is always recommended.This ensures that rain and dirt are washed away effectively. However, using 9 degrees is not a problem if the awning can be adjusted to that angle. - Is the awning always fully extended?
- Is a length of 195 cm (77 inches) absolutely necessary?
V
VolkerRacho8226 Mar 2025 17:31But dirt and rain should be able to drain off well if it does get wet. And yes, I am about 1.90 meters (6 feet 3 inches) tall and would appreciate being able to pass through comfortably.
nordanney26 Mar 2025 17:40VolkerRacho82 schrieb:
But dirt and rain should drain off well when it does get wet. And yes, I’m almost 1.90 m tall (6 ft 3 in) and would prefer to be able to pass through comfortably. You don’t always have to fully extend it anyway. Then you also have more headroom. I don’t see a real problem with 9 degrees — I already explained the reason for the “standard.”
