ᐅ In winter, it is cold; in summer, it is hot. The choice of material for a house’s structure plays a crucial role in managing indoor climate and energy efficiency throughout the year.
Created on: 25 Nov 2019 05:50
Ilya_Volkov
Hello everyone. I have a question about where I live, with winters around -30°C (-22°F) and summers around +30°C (86°F). Which building material is best for constructing a house under these conditions? What would you choose to build with? The house is a single-story private home with gas heating, and there is a river nearby. Your ideas on this topic would be interesting. Thank you.
Ilya_Volkov25 Nov 2019 08:42haydee schrieb:
Then take that. It’s proven.
[/ QUOTE]
Thank you for your input. However, wood is sensitive to moisture. Is it possible to build using bricks with good insulation? I believe this type of construction will be more durable.Ilya_Volkov schrieb:
I was once told that wood handles temperature fluctuations best.
No matter what, I would build according to the regional standards. Maybe invest a bit more and, for example, apply waterproofing like a two-component bitumen coating, which also protects against moisture accumulation caused by snow on the walls.
Talk to different contractors in your construction region.
If you ask tradespeople to work with materials they are not familiar with, mistakes are likely to happen.
hampshire25 Nov 2019 10:07haydee schrieb:
If you get tradespeople to work with a material they are unfamiliar with, mistakes will happen. This is the most valuable advice you can give on the subject! I wouldn’t build with adobe in Germany either, even though, except for the very thick walls, it is almost ideal for a good indoor climate at all outdoor temperatures.
Ilya_Volkov25 Nov 2019 10:14In my region, multi-story residential buildings are made of concrete. They are comfortable in summer, but cold in winter. Therefore, I have decided to ask from an expert’s perspective which option is better. Thank you.
hampshire25 Nov 2019 10:18I once had a keyboard like that too...
Concrete is used in multi-story buildings primarily because of its cost-effectiveness and structural properties rather than its climate benefits.
If you choose concrete, you need to pay special attention to the heating and cooling systems. Of course, that is possible. I prefer wood myself – I even built a wooden house here in Germany.
