ᐅ In the bathroom, the Kallax unit gets stained more quickly – would a clear varnish help protect it?
Created on: 3 Sep 2024 08:42
Tanzar
Tanzar
3 Sep 2024 08:42
I have a Kallax shelf in my bathroom that is now getting stained much faster than in other areas of the apartment. This is probably due to the higher humidity level and possibly splash water. My main question is:
Is it practical to protect the Kallax shelf in the bathroom with a clear varnish to make the surface more resistant to stains and moisture, without affecting the appearance or function?
It would be important for me to know which type of clear varnish is best suited (e.g., water-based vs. solvent-based) and if there is anything special to consider for this use.
Thanks for your experiences and advice!
likuken
3 Sep 2024 09:17
Tanzar schrieb:
whether the appearance or function suffers as a result?
In my opinion, this concern is justified. Clear varnish often noticeably changes the surface feel; sometimes it makes the material feel somewhat plastic-like or even causes slight yellowing, depending on the product. Therefore, I doubt whether the stylish, minimalist design of the Kallax can be preserved this way.
Furthermore, I fundamentally find it problematic to simply seal furniture “in the bathroom” with varnish. A much smarter approach would be to reduce the actual sources of moisture. Clear varnish is not a cure-all, but rather a symptomatic fix.
What is your opinion on this somewhat more radical approach?
pikin
3 Sep 2024 09:41
Factually correct. For wood-based materials or coated panels, a solvent-based clear varnish—alkyd resin or two-component polyurethane—is recommended for the best water protection. These varnishes are more durable and water-repellent than water-based varnishes.
Alternatively, hard sealers or water-repellent varnishes can be used, but they do not provide the same long-term resistance against moisture and stains.
Proper surface preparation (cleaning, sanding, degreasing) is essential to ensure optimal adhesion of the varnish.
Ramon4
3 Sep 2024 10:22
I agree with the previous comments and would like to add the following:
The Kallax is usually made of melamine-coated particleboard. The surface is generally fairly resistant to moisture, but this coating is not waterproof. Even small damages or scratches can allow moisture to penetrate and cause stains.
A clear lacquer can help seal the surface but should be applied generously and evenly. Make sure to coat the edges well, as this is where water can easily enter.
Before applying the clear lacquer, it is advisable to lightly sand the surface to improve adhesion. Test a small area first to check if the lacquer is compatible with the original color and finish.
Application: apply 2-3 thin layers, allowing each layer to dry thoroughly between applications.
KNUTGI
3 Sep 2024 11:33
Ramon4 schrieb:
A clear varnish can help seal the surface
Exactly! And honestly, you can also make the shelf look really nice with clear varnish – completely different, but not necessarily worse.
Increasing water or moisture protection doesn’t mean you have to cover the shelf in plastic 😉 A matte clear varnish often provides excellent protection while preserving the original design very well.
I also recommend: If you use clear varnish, definitely choose a breathable one, meaning it doesn’t fully seal the surface, so the board underneath won’t swell. It’s a fine balance, but that way you’re on the safe side.
Paunon
3 Sep 2024 12:15
Clear varnish is fine if applied correctly.
Moisture usually enters through exposed edges. So, seal the edges first.
Otherwise, apply multiple thin layers, not thick ones, to prevent the finish from cracking.
