ᐅ Improving Kallax Doors with Soft-Close Mechanisms – Product Recommendations?
Created on: 30 Apr 2024 19:37
Tau69
Tau69
30 Apr 2024 19:37
I plan to add doors to my IKEA Kallax shelves and would like to equip the doors with soft-close dampers to ensure gentle and quiet closing. My specific question is: Which soft-close dampers are best suited for Kallax doors, especially regarding load capacity and ease of installation?
I want to avoid major modifications to the shelves, so the dampers should be easy to retrofit, ideally without special tools. I am also interested in recommendations about damping strength – are there differences that matter for the frequently used Kallax doors?
If any of you have experience with particular brands or models, I would greatly appreciate your tips and advice. I have already noticed that there are different types of dampers, such as closing dampers mounted at the bottom of the door or those installed on the hinge side, but which option is typically preferred?
Thanks in advance for your help!
Filippo
30 Apr 2024 20:16
Hello Tau69,
a very good and specific question, which I’m happy to answer in detail since I have equipped several Kallax variants with furniture dampers myself.
First, regarding the type of dampers: For Kallax doors, soft-close dampers that are mounted directly on the door track are especially recommended, as they take up less space and offer an elegant solution. Brands like Blum and Hettich, for example, offer so-called “soft-close” dampers designed specifically for cabinet hinge doors or also as separate closing dampers.
Important when choosing them is the load capacity: Kallax doors are usually made of lighter MDF or particleboard with a laminate finish. The dampers should have a damping force of about 10–15 Newton to ensure smooth closing without making the door too slow or hard to operate.
Installation: The most commonly used soft-close dampers are usually fixed with screws. A cordless drill can be helpful but is not absolutely necessary, as suitable screwdrivers are sufficient. I have had good experiences with self-adhesive versions that are additionally screwed in — this ensures a secure fit, especially for frequently used doors.
One last tip: Make sure the damper is not too wide for your Kallax frame, otherwise it may cause problems when closing. Most suppliers provide exact measurements. If you want, I can gladly compile a list of my preferred models and sources for you.
What are the door size and material on your shelf? That will help me give you a more precise recommendation.
RENMA
1 May 2024 08:05
Filippo schrieb:
First regarding the type of dampers: For Kallax doors, closing dampers that are mounted directly on the door guide are especially recommended, as they take up less space and provide an elegant solution.
That is correct. I would like to add that when choosing furniture dampers, special attention should be paid to compatibility with the hinges. Since Kallax doors often use concealed hinges (also known as cup hinges), so-called "cup furniture dampers" are suitable. These can be fitted directly into the hinge cup hole.
Furthermore, I recommend considering the following aspects:
- The force of the damper should correspond to the door size: 8-12 N is sufficient for smaller doors, while larger ones require 15-20 N.
- Installation position: Usually mounted at the bottom of the door, so the damping element works optimally when closing.
- Mounting: A combination of screws and adhesive pads increases stability, especially for doors that are used frequently.
My tip: Blum soft-close dampers are durable and easy to retrofit, often compatible with Kallax since the door thickness is usually 16 mm (0.63 inches). However, it is worth measuring the exact door dimensions to select the appropriate damper.
I hope this provides more clarity in your choice.
warrenka57
1 May 2024 09:47
Hello Tau69 and everyone,
I think it’s great that you’re considering soft-closing mechanisms. They make daily use much more pleasant and protect both furniture and nerves. Especially with Kallax, which is rather simple and functional, small details like these can add a lot of comfort.
A little personal experience: I equipped my Kallax shelves with so-called “push-to-open” door dampers. These can be combined with cabinet dampers and ensure that you only need to gently press the door, which then closes softly with damping. Installation was straightforward, although I always mounted the dampers with screws for maximum durability.
What was important to me: the dampers should not only close the door softly but also prevent it from slamming shut loudly. Reading your question, it seems that this is important to you as well. ;-)
Maybe this could be an option for you too.
Do you have any special requirements regarding the appearance of the dampers? For example, should they be invisible?
Josefane
2 May 2024 12:03
warrenka57 schrieb:
I equipped my Kallax shelves with so-called "push-to-open" door dampers. These can be combined with furniture dampers and ensure that you only need to lightly push the door for it to close smoothly with damping.
Interesting, but I wonder whether a push-to-open mechanism is really necessary if the doors can already be fitted with standard hinges and traditional furniture dampers. Adding this extra mechanism increases complexity and potentially the points of failure in operation.
Filippo schrieb:
The dampers should have a damping force of about 10–15 Newton to make closing really smooth, without the door becoming too slow or difficult to move.
I would like to question these values critically: is the damping force you mentioned based on empirical data or is it more of a rule of thumb? In case of doubt, a damper that is too strong could cause long-term damage to the moving door parts, especially the hinges.
In general, I think we should also consider the mechanical stress on the Kallax shelving unit. How robust are the door mounts, and can they actually withstand the additional forces that might result from stronger damping systems?
Are there any studies or practical experiences available that provide a more comprehensive look at this topic? I find that important for making a reliable product recommendation.
