ᐅ Improving the Floor Plan of a 1½-Story Single-Family House
Created on: 3 Jul 2017 22:23
bindig
2D floor plan of a house: living room, kitchen, dining area, bathroom, and staircase
2D floor plan of a house with three rooms, staircase, and kitchen area
Technical floor plan with central staircase, exterior wall, and dimensions
Site plan of a residential area with property boundaries, building sketches, and road layout.
Thank you for all suggestions!
Development Plan/Restrictions
Building gap in an older residential area, no detailed development plan, but subject to §34
Plot is surrounded by roads on three sides
Plot size = 610 m² (6566 sq ft)
Slope = approx. 0.50 m (1.6 ft) south-facing slope
Site coverage ratio = not explicitly defined
Floor area ratio = not explicitly defined
Building envelope, building line, and limits = not explicitly defined (state building code requires 2.50 m (8.2 ft) distance)
Edge development = a neighbor’s shed at the northeast boundary
Number of parking spaces = 4 (state building code requires: 2 per dwelling unit)
Number of floors = 1 ½ (presumably required due to §34)
Roof type = gable roof (presumably required due to §34)
Architectural style = similar to surrounding buildings (§34)
Orientation = unclear, existing buildings are varied
Maximum height/limits = unclear, existing buildings mostly around 7.50 m (24.6 ft) ridge height
Other requirements = none known
Immediate surroundings have no trees
Owners’ Requirements
Architectural style, roof type, building type = no preference, just what’s allowed
Basement, floors = no basement (budget reasons), desired number of floors is 2, but only 1 ½ permitted
Number of residents, age = initially Dwelling Unit 1 (ground floor): 2 adults (tenants or holiday renters) + Dwelling Unit 2 (attic): 2 adults, 1 child (2 years old)
In about 10 years, after conversion to a single-family house: 2 adults
Space requirement on ground and upper floor = small, current space needs not permanent, DU2 (attic) needs about 10 m² (108 sq ft) of storage space in basement/attic
Office: family use or home office? = no dedicated office but a utility/cleaning/common room
Overnight guests per year = none
Open or closed architecture = open
Conservative or modern construction style = no preference, just what is permitted
Open kitchen, cooking island = open kitchen yes, cooking island only if space allows (therefore no)
Number of dining seats = initially DU1 (ground floor): 4 + DU2 (attic): 4
Fireplace = no
Music/sound system wall = no
Balcony, roof terrace = no (budget reasons)
Garage, carport = no (budget reasons)
Utility garden, greenhouse = no
Additional wishes/special requirements/daily routine, also reasons why certain things should or should not be included
= Single-family house divided into two small rental units for a few years, one rented to relatives,
- to avoid a separate utility room on the ground floor, building services/heating/ventilation systems will be distributed between the common room and the attic,
- the seemingly “normal” dormer on the south side is omitted mainly due to budget,
- the roof pitch is steep (45°) to maximize usable space,
- the house orientation should allow wide unobstructed views and solar panels should be feasible,
- the site is very sunny, so excessive south-facing windows are not desired
Planning source = do-it-yourself
What do you particularly like? Why? = House can be easily converted into a single-family home
What do you dislike? Why? = Ground floor space utilization is not optimal, no practical option to add a balcony later on the attic floor
Cost estimate according to architect/planner = unknown (“can be done very nicely for 400000”)
Personal budget limit for house including equipment = 200000 (two hundred thousand), excluding kitchen and furniture
Preferred heating system = district heating (required by the municipality, but acceptable)
- can you give up = everything “common today but not 20 years ago,” kitchens, glass panels in front doors, separate dressing rooms, roller shutters on north/west/east, roof windows
- reluctant to give up = underfloor heating (because it is hard to retrofit)
- cannot give up = utility/cleaning/common room, some storage space somewhere, division into two rentable units
Why did the design turn out as it is now? = A mix of many examples from various magazines/internet, simplified/reduced to fit the very limited budget
By the way, the light blue shaded rectangles on the site plan are intended to represent parking spaces for cars
Nordlys
16 Jul 2017 19:29
With a roof pitch of about 30 to 35 degrees and attic trusses, you get a very usable attic space for storage. If space is tight, avoid designing with angles, as angled structures are more expensive. Instead of a ladder to the attic, install stairs, so the attic is as accessible as a basement but without the cost of a basement. Our house measures 13.5 by 10 meters (44 by 33 feet) and has four rooms: living room, bedroom, office, guest room, kitchen, bathroom, guest toilet, and utility room. It costs 163 plus 8 for the garage, 5 for the kitchen, plus the usual additional building costs. Come on, get started, you can do it! Karsten
