ᐅ Improving Door Security Against Burglary?
Created on: 21 Jan 2019 14:14
Anoxio
Anoxio
21 Jan 2019 14:14
We have two secondary entrance doors that could ideally use some extra burglary protection. Do you have any tips on retrofit systems that could be used for this? The doors are made of uPVC with partial glazing.
I would be very grateful for any suggestions 🙂
O
Obstlerbaum
21 Jan 2019 15:10
The simplest retrofit solution is likely crossbars spanning the entire door width.
21 Jan 2019 21:45
Place a dog bowl in front of it.
Nordlys
21 Jan 2019 22:06
In our area, there was actually a break-in on New Year's Eve. Not at our place, but at others. Why not at ours? No idea. We were at a party and not home until 4 a.m. But maybe the house looks too humble? Doesn’t matter. I cut a board to wedge under the door handle, so it can’t be forced down, and that keeps the door secure. I don’t have a good idea yet for the patio door. The front door has these five mushroom-shaped bolts, so I trust it offers some resistance.
21 Jan 2019 22:30
Nordlys schrieb:
I cut a board to size and wedge it under the door handle, so it can’t be turned and the door stays closed.
If the door is forced open, the board won’t help. It doesn’t prevent that.
If you had a lift-and-slide door, you could place your board in the track there.
11ant22 Jan 2019 00:46
Nordlys schrieb:
I have now cut a board and wedge it under the door handle, so it can't be removed and that way the door stays closed.
Then you must use the emergency exit door yourself *LOL*
