ᐅ Ikea Visit and Purchase – More Frustration Than Enjoyment This Time
Created on: 22 Oct 2017 18:25
Yesterday we went to IKEA. Something felt 'different' compared to our last visit. I didn’t feel the usual excitement. Even today, assembling the furniture was rather unsatisfying.
But starting from the beginning: I’m used to IKEA introducing many new designs and changes in their showroom after the new catalog is released. Yes, some “rooms” were new, but the sofa, bed, and table sections seemed unchanged. There was no eye-catching display. Worst of all: the dining tables and sofas looked more like clearance sale items. Nothing was decorated or nicely arranged [emoji33]. I barely noticed the kitchens. Just around the corner was the appliance and planning section – normally there are two large standout kitchens set up where you can see various cabinets and get inspired. Well, this time I wasn’t motivated at all to buy anything not on my list [emoji1].
We needed LED bulbs for our outdoor wall lights: both the lamps and the LED bulbs are from IKEA. One of the bulbs is defective. We needed 7W with 260 lumens to match the brightness of the other bulbs, but those are no longer available! They only had 5W bulbs with different lumen outputs. Where have the outdoor lights gone? Are they discontinued??? Every corner had these 5-watt bulbs, but no 7-watt ones... so we ended up buying four 5W bulbs instead of one or two to fit all our outdoor lights [emoji36].
Then I had an idea to buy under-cabinet lights, meaning light strips to go under our new bedside consoles. This would save us the indirect cozy lighting from two floor lamps by the bed. Here they seem to have drastically reduced the selection: in a small area, you need to figure out the difference between task lighting, indirect lighting, cabinet lighting, and strip lighting. It’s not easy when products are mixed up on the shelves as other customers pick up items and don’t put them back properly. Fortunately, my husband noticed that I was about to buy a cabinet light while I realized he was holding an expensive task light. In the end, we found what we were looking for… hopefully [emoji6].
Originally, I wanted two white Besta units, 30cm (12 inches) high with doors to serve as bedside tables. Nicely wall-mounted, as I mentioned, like console tables. They cost about €30 each. My husband liked the drawer version of Eket much better. Well, we swallowed that: those cost about €85 each. Ok, we’ll go with it. I’ve been looking for bedside tables for 3 years, know the prices, and know what else is missing from the market [emoji6]. Unfortunately, there were no shelf or compartment info cards on the furniture anymore [emoji35]. Since when is that a thing??? We had to rely on the computers in the warehouse. We didn’t remember “Eklet” at first, so we flipped through the catalog, then on the PC had to choose between storage, shelving systems, drawer units, and eventually bedside tables, which barely appear. My husband wisely went to a separate PC to search directly for Eklet. I wouldn’t have been surprised if only one item was left in the compartment (that always seems to happen to us), but there were still plenty available. Then we went to the bargain corner where almost nothing was advertised. That is also very rare at IKEA.
-> And my husband asked if the wall rail for mounting was included. I said: at that price everything should be included... of course it wasn’t, which we only discovered during assembly [emoji20]. After assembling the first cabinet, we started the second one. And what do we see? A nasty air bubble worked into the top surface: I’ve never seen this before, never had this, and tomorrow it will send me into a traffic jam on the A1 – but oh well: I still have to buy wall rails anyway [emoji14].
White kitchen countertop with small dent and scratches
Then I looked closer: the other cabinet has the same issue, just a smaller air bubble inside. For €85, I really find this unsatisfactory [emoji20].
28 Oct 2017 15:04
winnetou78 schrieb:
Looks nice,
Is the silicone under the base tiles already cracking?
Yes, everywhere [emoji20] Unfortunately, we had the silicone installed before moving in [emoji848]
Now, of course, it’s tedious and expensive to redo everything... we hardly even notice it anymore... [emoji33]
kaho67428 Oct 2017 15:09
Yes, we also had enormous cracks in the silicone joints. We had the largest ones repaired. Apparently, this cannot be avoided in new construction.
Musketier28 Oct 2017 23:22
Same here. I also started redoing some of the joints. The most time-consuming part is removing the old material and cleaning the area.
Nordlys
29 Oct 2017 11:15
Yes, everywhere [emoji20] unfortunately we already had the silicone applied before moving in [emoji848]
Now it’s obviously pointless and expensive to redo everything... we barely even notice it anymore... [emoji33]
So what... it happens.
You can do it yourself. Pure winter hard work. Utility knife, remove old sealant. Mask off. Reseal. Better to use window sill sealant than sanitary sealant. The former is more elastic and has stronger adhesion, but it’s also more expensive. Product recommendation: Lugato "like rubber."
Karsten
tomtom7929 Oct 2017 14:25
So far, there is nothing visible at our house! But we have a prefabricated house on a basement—maybe that reduces the movement?
29 Oct 2017 17:04
The screed settles over time. This can, of course, cause the joints to crack. It is never possible to say exactly whether it will settle by half a centimeter (0.2 inches) or one centimeter (0.4 inches), and whether the joint will generally withstand this.
