ᐅ Looking for dimensions of the IKEA Rutinerad oven and Metod upper cabinet, as well as the cable length.
Created on: 3 May 2015 09:38
BirteHello everyone,
I am planning to install a RUTINERAD oven in the Metod tall cabinet. The cable length is specified as 82 cm (32 inches), which might be a bit too short for the power outlet, depending on the height where the cable exits the back of the oven. If I wanted to adjust the power outlet accordingly, quite a few tiles on the wall would have to be removed... Can someone tell me exactly where the cable is fixed on the oven and/or if the cable can be replaced by an electrician? The electrician will come anyway to make the final connection.
Second question: How much space do you need between the ceiling and the top edge of the cabinet for wall cabinets to hang them properly? I would like to have the 100 cm (39 inches) tall wall cabinets, but the kitchen ceiling height is only 2.50 m (8 ft 2 in).
Thanks a lot!
Thanks a lot!
IKEA-Experte3 May 2015 13:33Hello,
the user manual of the RUTINERAD oven states:
Power cable:
Compatible cable types for installation or replacement: H07 RN-F, H05 RN-F, H05 RRF, H05 VV-F, H05 V2V2-F (T90), H05 BB-F
Therefore, replacing the cable should not be a problem.
The upper cabinets basically only need enough space to be hung on the rail, so approximately 2cm (1 inch).
Power cable:
IKEA-Experte3 May 2015 13:47If the clearance to the ceiling is really that tight, you need to check beforehand whether unevenness in the floor and ceiling might reduce the distance too much. I cannot say to what extent 2 cm (1 inch) is sufficient for ventilation when installing appliances in a tall cabinet.
Me again... Ikea has finally responded to my question about the upper cabinets and the required clearance. They say I need at least 10 cm (4 inches) of space if I hang them using the rail system. I can’t really imagine that, since the mounting holes aren’t in the middle of the cabinet, are they? I would have expected more like 2 cm (0.8 inches).
One more question: if the tile backsplash doesn’t reach up to the top edge of the cabinet, do I need to install a separate spacer strip in between? In my old kitchen, I did that, but the cabinets were mounted directly against the strip and the wall.
