ᐅ Ikea Pax Auli/Färvirk Doors – Drawers Interfere with Sliding Door
Created on: 9 Aug 2015 21:39
PrenzlBerger
PrenzlBerger
9 Aug 2015 21:39
I assembled a Pax wardrobe with AULI/Färvik doors this weekend.
2 * Pax carcasses 100 x 58 x 236 cm (39 x 23 x 93 inches)
1 * Auli/Färvik sliding door pair 200 x 236 cm (79 x 93 inches)
2 * Komplement drawers 100 x 58 cm (39 x 23 inches)
2 * Komplement snap fittings
1 * Komplement drawer with glass front 100 x 58 cm (39 x 23 inches)
Overall, everything went quite well. The doors are installed (the mirrored door on the front left side, the frosted glass door on the rear right side). However, when I inserted the first drawer at the bottom left, I realized it cannot be pulled out. It hits the front sliding door. See this picture as well:
What did I do wrong?
If it matters: I haven’t installed the rails on the right and left yet.
IKEA-Experte
10 Aug 2015 12:54
Hello, the door will probably need to open wider. Loosen the stop and try if it can be moved further outward.
PrenzlBerger
10 Aug 2015 15:03
Thank you for the response! I have already pushed the stop as far outward as possible within the oval hole.
Could it be that I installed the "large" and the "small" stop, which is meant to be mounted on the inside for the locking system, reversed? I have now installed the large stop on the left (front sliding door) and the small stop on the right (rear door).
I’m really puzzled...
IKEA-Experte
10 Aug 2015 16:28
Large or small stop? In any case, non-identical parts must be assembled exactly according to the instructions.
PrenzlBerger
10 Aug 2015 17:43
...I meant these metal brackets that came with the mounting kit for the snap fitting (for quiet closing of the sliding doors). They are different sizes. In my opinion, I installed them correctly.
Are there any other ideas what might be causing this?
IKEA-Experte
10 Aug 2015 19:29
First, check where the door stops and prevents further opening.
