ᐅ Ikea Metod: Which Tools Are Essential for Assembly?
Created on: 21 Dec 2018 09:34
alrikdeo
alrikdeo
21 Dec 2018 09:34
I am planning to install an Ikea Metod kitchen unit in the next few weeks and want to prepare well in advance. I have a question: which tools are truly essential for assembling the Ikea Metod kitchen furniture?
I already have some basic tools at home, such as a hammer, screwdriver, and spirit level, but I am unsure whether a cordless drill is really necessary or if standard tools will be sufficient.
I am also interested to know if there are any special tools that can significantly simplify the assembly process or save time—especially when working with many cabinets and fronts.
I look forward to your experiences and advice, especially if you can recommend any useful tricks or must-have tools.
Best regards!
poted
21 Dec 2018 10:18
Hello alrikdeo,
I’m happy to take the time to answer your question thoroughly, as assembling an Ikea Metod kitchen can be quite challenging, and having the right tools is crucial for a good result.
First of all, I definitely recommend a good cordless drill/driver. Most connections consist of Minifix connectors and wooden dowels, which can be tightened by hand, but a cordless drill makes the work much easier and saves time, especially when setting up multiple cabinets. Make sure the drill has adjustable torque settings to avoid damaging the material.
In addition to the cordless drill, a standard Phillips screwdriver is important, as many screws need to be manually tightened or adjusted.
A rubber mallet is very useful because you can gently join the parts without damaging the wood or plastic. Standard hammers with metal heads can quickly cause unsightly dents.
For leveling, I recommend a spirit level, ideally one with a vial for greater accuracy. This is essential, especially for base units and for aligning the individual modules with each other.
Also, a small, sturdy flathead screwdriver can sometimes be helpful when you need to release small clips or covers in hard-to-reach places.
You should also have a tape measure ready to measure distances precisely, especially if the kitchen is being installed in a niche.
Additionally, a protractor (angle finder) is useful for checking right angles when assembling corners.
If you need to drill tiles, keep in mind you’ll need a tile drill bit, but this usually only applies to wall mounting upper cabinets.
A question for you: Do you already have the correct screws and the assembly instructions at hand? Did you encounter any special challenges, such as very uneven floors or walls?
Best regards!
LAURE-TA
21 Dec 2018 11:45
poted schrieb:
I’m happy to take the time to answer your question in detail, as assembling an Ikea Metod kitchen can be quite challenging and having the right tools is crucial for a good result.
I agree and would like to clearly outline which tools you definitely need in your toolbox for assembling the Metod system:
- Cordless drill with various bits – essential for Minifix connectors and for driving screws quickly and securely
- Phillips screwdriver – for tightening and fine adjustments
- Spirit level – to ensure cabinets are aligned and positioned correctly
- Tape measure – for accurate measuring of installation spaces or gaps
- Rubber mallet – prevents damage when fitting parts together
- Allen keys (hex wrenches) – often provided by Ikea, but having a set in various sizes is useful
I would add that when working with fronts and drawers, a sometimes overlooked tool is a small flathead screwdriver. It’s helpful for adjusting fronts or easily setting drawer clips.
And very important: always follow the assembly instructions step by step and in the correct order. The manual itself is often the best “tool guide” since it also points out special tools needed for particular steps.
If you like, I can also send you a brief checklist of areas to check before you start assembling.
Best regards!
Samuel
21 Dec 2018 12:02
Hey @alrikdeo,
not everyone has a cordless drill on hand, but I would really recommend getting one. It’s basically the superhero when assembling Metod – it helps not only with the screws but also saves your hands and time!
What I can also suggest is a bit of patience and a good amount of coffee – that helps more than some extra tools 😉.
Also, a little practical tip: put down a blanket or mat on the floor to protect your cabinet fronts and carcasses from damage when you set them down.
By the way, I’ve heard that Ikea sometimes includes a special tool attachment for the connectors. That’s a nice bonus if you don’t have the right bit yourself.
Good luck, the assembly will surely turn out great!
PULAU
22 Dec 2018 08:47
Hello alrikdeo,
I would like to build on the points already mentioned and highlight two especially important tools that are sometimes overlooked: a small water pump pliers or pliers in general, and a suitable utility knife.
Pliers are useful for holding or positioning metal clips, edges, or even screw heads. Sometimes, especially during the substructure work, you need to manage small metal parts.
A utility knife is needed for cutting packaging, protective films, but also for trimming seals or membranes afterward. Make sure the blade is sharp to ensure the job is done safely and cleanly.
One more tip: Even if it sounds obvious, allow yourself enough time so you don’t have to rush. Carefulness at every step helps to avoid mistakes and ensures the kitchen will be stable in the end.
Best regards!
Davidleo
22 Dec 2018 09:15
Samuel schrieb:
Not everyone has a cordless screwdriver ready at hand, but I really recommend one. It’s basically the superhero when assembling a Metod – it helps not only with the screws but also saves your hands and time!
That’s exactly what I want to say! A good cordless screwdriver is worth its weight in gold. Last year I assembled my first Metod, and without a cordless screwdriver I would still be screwing away 😂
But besides the tools, I also think a bit of enthusiasm and motivation helps. If you prepare well and have the right tools, putting it together can actually be a lot of fun!
My tip: Take a short break now and then so your motivation doesn’t drop. And be proud once the kitchen is assembled – you’ve earned it! 😀
