ᐅ IKEA Metod: How do I securely install wall cabinets on different types of walls?
Created on: 21 Feb 2023 08:17
Pintau
Pintau
21 Feb 2023 08:17
I am currently planning to remodel my kitchen and want to securely mount the IKEA Metod wall cabinets on various wall types. My main concern is the stability and appropriate fastening methods depending on the wall material. Specifically, my kitchen has a combination of a load-bearing concrete wall, drywall partitions made of gypsum board, and in some areas, a load-bearing brick wall.
I have reviewed the IKEA installation guide, but the instructions are quite general—for example, they recommend attaching the cabinets to studs or solid walls.
I’m interested in:
- What types of anchors or fasteners are best suited for the different wall types?
- How can I safely mount wall cabinets on drywall, which often does not support heavy loads?
- Are there any special tips or precautions when mounting on brick or concrete?
I would appreciate any experiences, recommendations on suitable tools or installation methods, and potential mistakes to avoid.
Thank you in advance!
Jeffon
21 Feb 2023 08:45
your concern is completely understandable. When installing IKEA Metod wall cabinets on different wall types, the following points are crucial:
- Concrete walls: Heavy-duty anchors (e.g., metal expansion anchors or chemical anchors) are the best choice. They provide the necessary load-bearing capacity and safety.
- Brick walls: For solid bricks, plastic expansion anchors or special impact anchors work well, provided the brick is not too crumbly. It is important that the anchor length and diameter match the screw and the load requirements.
- Drywall/plasterboard: Use hollow wall anchors (e.g., toggle anchors, metal hollow wall anchors) that distribute the load over a larger area. Alternatively, you can mount the cabinets directly to the supporting studs behind the drywall if accessible.
Additionally, pre-drilling with suitable drill bits and checking the wall condition on-site is recommended. If studs are present, fastening directly to them increases safety.
Avoid screwing only into the drywall without proper anchors. Most accidents involving wall cabinets occur due to incorrect fastening in drywall.
If you have questions about selecting individual anchor types or load capacities, feel free to ask.
nojaus
21 Feb 2023 09:03
Jeffon schrieb:
If there is a stud frame available, you can attach directly to it, which increases safety.
I can only agree with that. When you have the chance to hit the stud, you also feel much more secure during installation. I was once worried myself because I thought my drywall wouldn’t support the weight.
In my case, I started with smaller cabinets and was then able to plan the installation more securely step by step. With drywall partitions, I was initially hesitant too, but with the right cavity anchors, it held surprisingly well.
My advice: Even if it sometimes takes a lot of effort, always double-check that you are really in the stud. It’s better to spend an extra half hour measuring than risk the cabinets falling down.
JEREMIAH38
21 Feb 2023 09:26
I would like to add that when dealing with brick walls, it is important to pay attention to the quality of the masonry. Older walls in particular can be crumbly, and standard anchors may not hold well in such cases. It is worthwhile to test the stability with a small pilot hole before installation.
Additionally, I have had good results using longer screws and anchors, as they provide better grip than shorter ones.
Another point regarding drywall: sometimes it helps to distribute the load across multiple points – so instead of just two screws per wall cabinet, use more fastening points. This reduces the stress on each individual anchor.
DULIS
21 Feb 2023 10:01
The following applies to drywall:
- Use metal cavity anchors
- Screw into a stud whenever possible
- Distribute additional load by using multiple screws
For concrete or brick:
- Heavy-duty anchors or chemical anchors
- Pre-drill with a suitable drill bit
sinhau
21 Feb 2023 10:37
Here is a simple step-by-step guide for installing IKEA Metod wall cabinets on different types of walls:
1. Identify the wall type:
- Concrete wall: solid and load-bearing
- Brick (solid or hollow): load capacity varies
- Drywall/plasterboard: usually mounted on stud framework, low direct load capacity
2. Load check:
- Determine the weight of the cabinet plus contents.
- Calculate a safety factor (at least 1.5 times).
3. Choose fasteners:
- Concrete: heavy-duty anchors such as metal expansion anchors
- Solid brick: plastic anchors or long-shank anchors
- Drywall: metal hollow wall anchors, possibly with anchor plates
4. Installation:
- Precisely mark the drill holes on the back panel of the cabinet.
- Use a drill bit with the appropriate diameter.
- Fully insert anchors or secure chemically if applicable.
- Select screws long enough for anchors and wall thickness.
5. Load distribution:
- For drywall, use several anchors rather than just a few.
- Whenever possible, attach cabinets to the stud framework.
6. Inspection:
- After installation, check that the cabinet is firmly fixed.
- Gradually increase the load.
Common mistake: Using screws that are too short or screwing only into the panel without transferring load to the studs.
