ᐅ Ikea Metod: How can I permanently fix a squeaky drawer?
Created on: 24 Apr 2022 19:37
liekrem
liekrem
24 Apr 2022 19:37
I have been having an issue for some time with an Ikea Metod kitchen drawer that constantly squeaks when I open or close it. This is a frequently used drawer equipped with Metod drawer runners. The annoying noise likely comes from friction on the sliding rails or possibly the rollers, but I’m not entirely sure.
I have already tried to fix the problem with common solutions such as silicone spray or lubricating greases, but these measures only work temporarily and the squeaking returns after a while. Otherwise, the drawer still operates smoothly; there are no noticeable jerks or other guide-related problems.
My question to you is: How can I permanently fix a squeaking Ikea Metod drawer to ensure it runs quietly all the time? Are there specific lubricants or techniques that have proven effective in the long term? Do I possibly need to replace or adjust parts, and if so, which components should I pay particular attention to?
I appreciate detailed and practical advice, thank you in advance for your support!
FEKAU
24 Apr 2022 20:05
Hello liekrem,
your description points to a common issue with the drawers of the Ikea Metod system. The squeaking noises usually come from dry or dirty runners or rollers. Temporary lubrication with silicone spray can help, but it often isn’t a long-term solution, as the spray attracts dirt or evaporates.
For a lasting fix, I recommend the following structured approach:
- First, fully remove the drawer to access all components easily.
- Thoroughly clean the runners and rollers from old lubricants, dust, and dirt using isopropanol or a mild solvent.
- Then apply a high-quality, non-resinous lubricant. PTFE-based or lithium grease lubricants are well suited for metal slides because they don’t dry out quickly and provide good sliding properties.
- Apply the lubricant sparingly on the guides and moving parts, avoiding excess to prevent dirt buildup.
- Optionally, check the runners for damage. Defective rollers or broken plastic parts should be replaced; spare parts are available separately from Ikea.
- After reassembly, slowly open and close the drawer several times to distribute the lubricant.
This method has proven reliable in practice. If the problem persists, adjusting the guide rails can help as misalignment can also cause noise.
In summary: Clean – lubricate carefully with a durable lubricant – check/replace damaged parts – adjust correctly.
I hope this helps you.
praWarre69
25 Apr 2022 08:13
FEKAU schrieb:
To permanently fix the issue, I recommend the following structured approach:
FEKAU sums it up perfectly! 😊 I just want to add that some people have also had good results by lightly treating the plastic rollers on the sides with a dry Teflon spray or even graphite powder – the latter is not a liquid but rather a powder that lasts longer. Liquid lubricants like oil or silicone tend to attract dust.
Also, be sure the drawer is not overloaded, as excessive weight can increase friction and cause squeaking. While you're at it, sometimes adding a thin padding of about one millimeter (0.04 inches) under the sliding surfaces, such as felt pads, can help dampen the movement.
Good luck with the repair—the squeaking can really spoil your breakfast enjoyment! 😄
PRA64
26 Apr 2022 14:42
liekrem schrieb:
How can I permanently fix a squeaky Ikea Metod drawer so that it runs quietly over the long term? Are there any special lubricants or techniques that have proven effective? Do I possibly need to replace or adjust parts, and if so, which components should I pay special attention to?
Very good questions, liekrem. I’d like to offer you a simple step-by-step guide specifically for the Metod system:
1. Remove the drawer and fully extend the slides.
2. Clean off all dirt and old lubricant residues using a lint-free cloth and isopropyl alcohol or a mild cleaner.
3. For lubrication, I recommend a dry PTFE spray or suitable lithium grease—both are effective for providing long-lasting lubrication without becoming sticky.
4. Evenly apply the lubricant to the metal tracks and plastic rollers. Important: Use only a small amount to avoid attracting dust.
5. Test the function by carefully opening and closing the drawer several times to check the sliding smoothness.
6. If noises persist, inspect the plastic rollers for cracks, breaks, or heavy wear. These should be replaced if damaged.
7. Adjust the alignment of the sliding rails using the adjustment screws to ensure smooth guidance.
It is important to proceed carefully throughout the process and avoid using aggressive substances that might damage plastic parts. Replacement rollers can be easily reordered from Ikea.
Using this method, the squeaking should be permanently eliminated.
