ᐅ IKEA Metod: How can I optimize the lighting in tall cabinets?
Created on: 5 Apr 2020 09:37
gilutfi
Hello everyone, I am currently planning the renovation of my IKEA Metod kitchen and am focusing specifically on the lighting inside the tall cabinets. My question is: how can I optimize the lighting in higher Metod tall cabinets to provide not only good general brightness but also convenient and practical usability? I’m looking for a combination of functionality and aesthetics because tall cabinets can quickly become dark and hard to see inside. Does anyone have tips on light sources, positioning, switching options, or suitable products that integrate well? I appreciate any ideas and experiences!
Wyatt
5 Apr 2020 11:27
Very good question, gilutfi! Access for wiring in Metod tall cabinets is indeed a challenge because the cabinets are modular and have relatively thin back panels. Usually, the back panels are not designed for concealed cable routing – I recommend planning the location of the power source (e.g., a nearby outlet or supply through a cabinet network) right from the start.
For power supply, I like to use flat cables that are barely noticeable and preferably run them along the joints between the cabinet modules, ideally hidden with adhesive cable guides. Ready-made LED sets from IKEA (such as the MULIG lamps) are easy to install but tend to be less flexible and mainly intended for the countertop area. For tall cabinets, separate 12V LED strips with power adapters are better suited as they can be placed more flexibly.
It is also important to use certified power supplies and avoid running wiring openly in cable ducts, as this can cause mechanical stress – in the worst case leading to failures or short circuits.
Do you already have a power outlet nearby, or are you planning a new electrical connection?
gilutfi
5 Apr 2020 11:45
I have a power outlet located directly behind one of the tall cabinets, so there is the option to plug in a cable there. I’m also interested in the possibility of installing a simple control device inside the cabinet itself (such as a switch or motion sensor), without relying on an external controller. This makes the setup a bit more complex for me. How do others handle this in terms of ease of use and cable management?
BARSAN
5 Apr 2020 12:02
I installed small touch switches on the inside of the doors of my tall cabinets. This works well and looks neat. The cables run along the back panel inside a cable duct, which is clean and unobtrusive.
putan
5 Apr 2020 12:23
A topic like this can really be fun! I installed a combination of LED strips and a small motion sensor that turns the light on as soon as you open the door. It makes everyday life much easier 😊. I routed the cable behind the back panel, securing it with cable clips – it looks very neat and is flexible for future removal. Tip: When buying the LED strips, skip RGB and choose warm white instead; it creates a much cozier atmosphere inside tall cabinets!
nanidra
5 Apr 2020 13:11
putan schrieb:
I routed the cable behind the back panel, fixed it with cable clips – it looks very neat and is flexible during modifications.
I really don’t like that. Why on earth wouldn’t you choose wireless solutions? They are now well-developed, easy to install, and eliminate all the cable clutter. Especially with Metod, where the units are often changed or moved, this seems like the better option to me.
Wyatt
5 Apr 2020 13:49
nanidra schrieb:
Why on earth wouldn’t you use wireless solutions?
That’s a valid question, but it’s important to consider that wireless or battery-powered solutions usually provide lower light output and often require frequent battery replacements, especially with heavy use. Additionally, some radio-based systems can be prone to interference and may respond with delays.
With a hardwired solution connected to the mains power, you have continuous lighting and no ongoing maintenance costs. You simply need to weigh your individual needs—whether the main focus is on convenience or reliable, permanent lighting.
