ᐅ IKEA Metod: How do I fix squeaky drawers?
Created on: 20 Mar 2022 08:13
peantonio
peantonio
20 Mar 2022 08:13
Good morning everyone, I have a problem with squeaky drawers in my IKEA Metod kitchen unit, which has become quite annoying. These are full-extension drawers with metal sides that make an unpleasant squeaking noise every time they are opened or closed. The construction itself seems solid, but apparently there is a friction point somewhere causing this noise. Before I start removing parts unnecessarily or even fully dismantling the drawers, I wanted to ask if anyone has had similar experiences with IKEA Metod drawers and what repair or maintenance steps are recommended to fix this squeaking? Are there specific lubricants that work well, or is the issue more mechanical in nature (e.g., guide rails, rollers, or tracks)? I look forward to concrete tips and instructions, as this requires a bit of technical understanding on my part. Thanks in advance!
Kinbu
20 Mar 2022 08:59
Hello peantonio, I’m familiar with the problem of squeaking METOD drawers; this happens quite often. Generally, such noises are caused by friction on the runners or metal guides, often when dirt or dust has accumulated. As a first step, I recommend carefully removing the drawers completely. Pull them straight out; usually, the metal rails are locked into the frame and can be released by gently lifting and pulling them out. Then, thoroughly clean the guide rails, preferably with a dry cloth or a small brush. Once the guides are clean, apply a suitable lubricant. It’s important not to use oil or grease, as these attract dust. The best option is a special silicone-based spray or Teflon spray. This creates a dry lubricating film and the drawers will glide quietly again. Then reinsert the drawers, making sure the guides fit precisely into the rails and slide in straight. If everything is correctly aligned, you should no longer hear any noise. If that doesn’t solve the problem, it might be caused by misaligned components, which can be adjusted with a small screwdriver on the runners. Feel free to ask if you need more information about this!
derrick34
20 Mar 2022 09:27
Remove the drawer, clean the guide rails, then apply silicone spray – that should stop the squeaking.
minan
20 Mar 2022 10:45
I would like to take a more technical look at this topic because METOD drawers with metal sides and full extension slides require precise functioning to glide quietly. Squeaking usually occurs when the runners are either not properly lubricated or the rollers do not run correctly on the rail. Here is a step-by-step guide that I have compiled based on my own experience and technical documentation:
- Fully extend and remove the drawer (usually by releasing a lever or push mechanism on the side)
- Check the guide rails and runners for dirt, foreign objects, or deposits and clean them with a lint-free cloth
- Inspect the rollers and sliding surfaces for visible damage or misalignment
- Apply a thin layer of lubricant based on silicone or PTFE to the metal runners, using it sparingly as too much lubricant attracts dirt and worsens the problem
- If the drawer has adjustment mechanisms for the runners, check and adjust them if needed
- Reinsert the drawer, making sure it sits evenly and that the locking mechanism engages correctly
I have also noticed that squeaking is often unintentionally amplified when drawers are overloaded or the rails are slightly bent. May I ask how heavily loaded your drawers are? This could help narrow down the cause.
peantonio
20 Mar 2022 11:12
minan schrieb:
May I ask how heavily loaded your drawers are? That might help to narrow down the cause.
Thank you for your detailed description, minan! The drawers are currently not overloaded, rather normally filled with kitchen utensils and cutlery. So, the load shouldn’t be too much. I will take a closer look later for any dirt and mechanical issues. I am particularly interested if there is a specific order to follow when cleaning and maintaining them to avoid missing anything. Are there common mistakes to watch out for during reinstallation? I want to avoid damaging the drawers.
Kinbu
20 Mar 2022 11:47
peantonio schrieb:
I’m particularly interested in whether there is a specific order to follow when cleaning and maintaining to avoid missing anything. Are there common mistakes to watch out for during reassembly?
That’s exactly right: having a clear sequence is really helpful. I recommend:
- Fully pull the drawer out of the cabinet and set it aside
- Clean the guide rails on both the frame and the drawer
- Apply lubricant sparingly
- After a short wait, reinsert the drawer
Common mistakes during reassembly:
- Guide rails not properly aligned or skewed
- Drawer not pushed in completely, so the locking hooks don’t engage
- Applying too much lubricant, which attracts dust
If you keep these points in mind, you’ll avoid most problems. It’s important to carefully inspect the mechanism to catch any hidden defects.
