ᐅ Ikea Metod: How can I clean matte cabinet fronts in an eco-friendly way?
Created on: 12 Apr 2024 08:37
Kin41Hello everyone, I have the IKEA Metod kitchen with matte fronts and I am looking for an environmentally friendly yet effective method to clean these surfaces. It is important to me that no harsh chemicals are used and that the matte finish is not damaged — after all, matte lacquered fronts can quickly develop unsightly shiny spots or micro-scratches.
Which cleaning products or home remedies do you use to gently but thoroughly remove dirt, grease, and fingerprints? How often should the fronts be cleaned to keep them in good condition over time? Are there any special techniques for application (e.g., using microfiber cloths or sponges)?
I look forward to practical, especially eco-friendly, tips based on your experience.
Hello Kin41, I understand your concern about the matte surfaces. It is important not to rub too hard to avoid altering the matte finish. A neutral cleaner based on vinegar water (e.g., 1 part vinegar to 3 parts water) works well, is biodegradable, and effectively removes grease. Use a soft microfiber cloth to clean the surfaces without scratching them.
Regular cleaning helps prevent stubborn stains from forming. I recommend a light cleaning once a week and, for heavy soiling, cleaning in between with the vinegar solution.
Regarding the sustainable cleaning of matte IKEA Metod fronts, I would like to explain the process in more detail. Matte lacquer fronts are more sensitive to abrasive or harsh cleaning agents, as the surface can easily become shiny or develop spots. Therefore, it is advisable to:
- First, remove dust with a soft, dry microfiber cloth.
- For grease or fingerprints, use a microfiber cloth dampened with lukewarm water.
- For stubborn stains, mix a solution of 1 part white vinegar and 3 parts water.
- Wring the cloth out well and gently wipe the fronts.
- After cleaning, polish with a dry cloth to avoid water spots.
Completely avoiding aggressive chemicals or scouring agents is essential. Additionally, I would recommend promptly wiping off splashes right after cooking to prevent them from setting in. How do you handle this currently, Kin41? This could significantly simplify maintenance.
Dilen schrieb:
How are you currently handling this, Kin41? That could make maintenance much easier.Thanks for the tip, Dilen. At the moment, I usually remove grease or stains in the evening when I have time, using a damp cloth and a common cleaner that often contains surfactants. However, I’ve noticed that some areas of the matte surface tend to darken slightly or appear glossier afterward, which I suspect might be due to incorrect or too aggressive cleaning.
Would regular, prompt removal of splashes with just lukewarm water actually be sufficient? Or would you recommend using the vinegar-water solution more frequently from the start? I’m also curious if there are significant differences depending on the cloth material—I currently only have standard kitchen cloths and microfiber cloths.
Regarding Kin41’s question about environmentally friendly cleaning of the IKEA Metod matte fronts, it should be noted that the surfaces need to be handled with care to avoid damaging the matte texture. My recommendations are based on the latest surface technology and cleaning experience:
- Using lukewarm water is sufficient in most cases for regular cleaning.
- Vinegar-water mixtures are suitable but should not be used too frequently to avoid damaging the paint layer; a maximum of once per week.
- Microfiber cloths with medium fiber length are ideal. Very coarse or very short fibers can cause more wear on the surface.
- Do not use harsh chemicals or abrasive cleaners.
- Dry wiping after cleaning is important to prevent water spots.
The frequency of cleaning should depend on the level of dirt. More frequent light cleaning is better than infrequent intensive scrubbing. This way, the surface stays preserved and maintains its microtexture.
