ᐅ IKEA Metod: How can I design kitchen units to be functional and space-efficient?
Created on: 30 Sep 2024 18:27
X
xiang42
X
xiang42
30 Sep 2024 18:27
Hello everyone, I am currently planning the layout of a new kitchen and have chosen the IKEA Metod system. My main question is: How can I create functional and space-saving kitchen runs using Metod? I am looking for an optimal solution both for storage organization and countertop use. It is important to me to minimize wasted space while still having enough storage for pots, pans, pantry items, and appliances. What tips do you have regarding module sizes, cabinet combinations, and possibly interior fittings (e.g., drawers, inserts) that make the most sense? Are there proven strategies to build an efficient kitchen run even in a narrow room layout? Thanks for your help!
Lorukeo
30 Sep 2024 19:03
For planning a functional and space-saving IKEA Metod kitchen layout, it is essential to first measure the available space accurately.
I recommend considering the following points:
- Use 60 cm (24 inches) deep base cabinets for optimal storage capacity, as these dimensions fit standard appliances and drawers well.
- Prefer drawers over doors, as they provide better access to the contents.
- Use internal drawers and organizer elements (e.g., cutlery trays, spice racks) to efficiently structure the storage space.
- For narrow kitchens, consider tall cabinets (up to 2.4 m (8 feet)) as pantry or utility cabinets to make effective use of vertical space.
- Plan the countertop as a continuous surface wherever possible to ensure enough workspace for food preparation.
It is also important to consider the kitchen workflow (the work triangle between the stove, sink, and refrigerator); the IKEA planner is very helpful for this.
KNUTGI
30 Sep 2024 19:47
The IKEA Metod system makes kitchen building almost a breeze! 😄 My advice: go for as many drawers as possible—they’re really practical and prevent things from getting lost at the back. For small kitchen sections, choose narrow units—they’re available from 20cm (8 inches) wide, perfect for filling gaps or storing slim appliances. Even better: drawers with soft-close mechanisms, which give a really high-quality feel. And for corners: rotating carousels or magic corners are real space-savers. Sometimes it’s worth investing a bit more here because clever corner solutions turn every centimeter (inch) of storage into gold! Enjoy planning—it will surely turn out great. 🍀
GALEO4
1 Oct 2024 08:12
KNUTGI schrieb:
And for the corner: carousel carousels or Magic Corners are the ultimate space savers.
I see it differently – carousel units take up more space than they save and are often difficult to clean and load. Being too clever with saving space can ultimately lead to losing storage capacity. It’s better to rely on well-designed drawer solutions that are truly accessible all the way to the back. Also, I find IKEA Metod’s dimensional standards personally too inflexible; especially in small kitchens, fixed grid sizes often leave too much unused space. In this case, a simple modular construction system is more of a hindrance than a help. Sometimes, less use of fixed measurements can lead to better space utilization.
GiRoyce
1 Oct 2024 10:25
This topic works best when you first carefully consider everything that needs to be stored. It often helps to reflect on your daily kitchen routine and sort your utensils before making a purchase. For Metod kitchens, I recommend:
- Plan drawers in various heights: shallow ones for cutlery and tools, deeper ones for pots and pans.
- Use internal organizers or dividers to keep cabinets neat and orderly.
- In narrow sections, shelves or racks in a 20 cm (8 inch) cabinet are very practical, for example for oil bottles or baking trays.
- Make sure that the countertop is not blocked by open drawers – consider pull-outs with stoppers or soft-close mechanisms.
- Also integrate pull-out pantry cabinets for food storage if space allows.
IKEA’s planning software is very helpful, offering the ability to generate parts lists and check dimensions precisely. If you like, I can also suggest a sample kitchen with typical measurements.
X
xiang42
1 Oct 2024 12:18
Lorukeo schrieb:
Plan the countertop as a continuous surface as much as possible to have enough space for food preparation.
That makes sense to me, thanks. However, I have a small room with only about 240 cm (94 inches) width for the kitchen area. The space is obviously limited there. Does anyone have experience on how to make the best use of the countertop in such a space without having to compromise while cooking?
Also, storage plays a big role: How do others manage to get enough storage for tools, pots, and food supplies in such tight spaces without the kitchen feeling cluttered? Are there any tricks to make a small room appear visually larger?
