ᐅ Ikea METOD: How to design kitchen units for ergonomic use and space efficiency?
Created on: 31 Mar 2021 08:42
tizianneo
tizianneo
31 Mar 2021 08:42
I am currently planning to redesign my kitchen using the IKEA METOD system and facing the challenge of arranging the kitchen units in a way that is both ergonomic and space-saving. I am particularly interested in how to organize the individual components (base cabinets, tall cabinets, countertops) effectively so that walking distances are short and work zones are clearly separated.
How can I maximize the functionality of METOD without overcrowding the space? And which ergonomic factors—such as working height, possible alternatives to traditional drawers, smart use of corner solutions—should I definitely consider?
I would greatly appreciate concrete tips and practical experiences, including advice on common mistakes to avoid.
Thanks in advance!
sonplo
31 Mar 2021 14:07
A really important question you’re raising. With IKEA METOD kitchens, it’s advisable to organize clear zones: cooking zone, washing zone, and preparation zone should be arranged in a logical sequence to avoid unnecessary steps.
For countertop height, I recommend customizing it to your height – the standard is often 91 cm (36 inches), but a good rule of thumb is: countertop height = elbow height minus about 10 cm (4 inches).
Corner solutions can be challenging; I prefer carousel or LeMans cabinets, which make storage space truly usable. I would avoid simple corner cabinets with swinging doors, as they are often inefficient.
One more tip: instead of just standard drawers, using pull-outs and organizer systems is worthwhile to make the best use of space.
Also, don’t forget to plan sufficient clearance space in front of the cabinets, at least 120 cm (47 inches) walkway width, even if this makes the room feel slightly smaller.
LANICOLE
1 Apr 2021 09:53
sonplo schrieb:
For the working height, I recommend adjusting it individually to your body height – the standard is often 91 cm (36 inches), but a good rule of thumb is: working height = elbow height minus about 10 cm (4 inches).
This is a very important point that I would like to elaborate on. The ergonomic working height is crucial to avoid back pain during extended periods of kitchen work. With IKEA METOD, you can customize the working height by choosing different plinth heights and countertop thicknesses.
Another tip: arrange the cabinets so that all key work zones are easily accessible – with at most 1 to 2 steps between the sink, stove, and refrigerator. This is known as the “work triangle” rule, which has proven effective.
Corner solutions can indeed be tricky; I recommend opting for pull-out units with full-extension slides or internal drawers instead of traditional hinged doors, as these are more usable and make it easier to find contents.
Space-saving strategies also include using tall cabinets with built-in appliances like microwaves or ovens, keeping the countertop surfaces more open.
Finally, I recommend using the METOD planner to determine exact measurements and avoid unnecessary walking distances.
kibutar
2 Apr 2021 11:18
When designing ergonomic and space-saving kitchen units with METOD, there are several critical technical aspects to consider:
- The working height should be precisely determined by measuring the optimal height for the user: top edge of the countertop at elbow height minus 10 cm (4 inches). This is physiologically sensible to reduce muscular strain.
- To efficiently utilize corner areas, I recommend using the METOD corner cabinet with a swivel carousel (also called a "Magic Corner"). It is important to correctly adjust the hinges and maximize the pull-out depth to fully use the interior depth.
- When planning, the following minimum clearances should be observed: at least 110 cm (43 inches) of free space in front of work surfaces, ideally 120 cm (47 inches). This provides enough room for working and opening drawers.
- The classic work triangle layout (refrigerator - sink - stove) remains best practice. Walking distances together should not exceed 6 meters (20 feet).
- Drawer units with full extension are particularly important in lower cabinets, as they allow complete access to contents. For smaller items, wooden or plastic internal organizers are very helpful.
What are your exact room dimensions? Are there any windows or doors to consider? Are there any recesses in the room that could be utilized?
U
umberto
2 Apr 2021 17:36
kibutar schrieb:
What are the exact dimensions of your room? Are there windows or doors to consider? Are there any alcoves or recesses that could be used?
This information is important. Without knowing the width of your room and which fixtures are present, any advice can only be general.
tizianneo
3 Apr 2021 08:25
kibutar schrieb:
What are the exact room dimensions? Are there any windows or doors to consider? Are there any alcoves or recesses that could be used?
Good question – yes, the room is just under 3.8 meters (12 ft 6 in) long and about 2.5 meters (8 ft 2 in) wide, rectangular in shape with a door on the left end wall and a window above the planned sink area. The idea was to design the kitchen line along the longer wall.
A traditional L-shaped layout is therefore unlikely – more likely a straight kitchen run with tall cabinet units. Storage space is somewhat limited, so I want to make the most of the available space.
It is also important to me that the worktop height is comfortable (I am 1.82 meters (6 ft) tall) and that the arrangement of elements is logical. The corner cabinet issue is less relevant here since there is no corner in this run, but I am still interested in ideas for managing small spaces.
Thanks in advance for the many helpful tips; I will take them into account when using the METOD planner.
