ᐅ Ikea Metod: How do I build kitchen islands with an integrated seating area?
Created on: 24 Jun 2017 18:37
BubalazsHello everyone,
I am planning to build my new kitchen using Ikea Metod and definitely want to include a kitchen island that also provides a seating area. My question is quite specific: How can I build Ikea Metod kitchen islands with an integrated seating area so that they are stable enough and the seating is ergonomically suitable? I am especially interested in which base cabinets work best, how to extend or modify the countertop, and any tips for secure mounting when aiming for counter height or bar height.
I would also like to know if anyone has experience combining seating with and without stools, and what the optimal height is for a kitchen island with an integrated dining area.
I would appreciate any helpful insights, practical advice, or general recommendations!
Hello Bubalazs!
I totally understand you; a kitchen island with a seating area is just super practical and also looks really stylish!
I built my Metod kitchen island the same way and can give you some tips:
- For the base, I always use standard base cabinets with a height of 80 cm (31.5 inches) and then install an extended countertop on the side where the seating area will be, which overhangs by about 30-40 cm (12-16 inches).
- For the seating height, I based it on bar stools, so my countertop there is at 105 cm (41 inches) height, simply by attaching an extra fascia board underneath. This adds stability!
- Very important: If the countertop overhangs, be sure to secure it firmly with strong brackets attached to one of the base cabinets or with additional supports—especially when the stools will be used!
Just go for it—the project is definitely doable! If you want, I can give you more precise measurements or tips on material selection. Good luck!
bauku schrieb:
For the seat height, I based it on bar stools, so my countertop is at 105 cm (41 inches) height there, with just an additional trim board screwed underneath. This provides stability!To look at this a bit more technically: The standard base cabinets from Ikea Metod are 80 cm (31.5 inches) high, plus 2-3 cm (about 1 inch) for the countertop, resulting in a typical working height of around 82-83 cm (32-33 inches) – optimal for standing and food preparation. For the seating area, usually paired with bar stools having about 75 cm (29.5 inches) seat height, the countertop should be approximately 105 cm (41 inches) high.
The modification/extension is usually done as follows:
- Base: A full base cabinet used as support (at least 60 cm (24 inches) wide for stability)
- On top of that, an additional cross rail (e.g., 4x4 cm (1.5x1.5 inch) wooden battens) is mounted, which is higher than the cabinet frame
- The countertop is cut so that it aligns flush with the cabinet side and cantilevers outward on the seating side accordingly
The attachment of the extension is crucial because strong leverage forces can occur here, especially when people lean on the seating surface. Supports like legs, a doweled cabinet frame, or bracket angles are practically mandatory.
Regarding the choice of base cabinets, larger cabinet units (60, 80 cm (24, 31.5 inches) wide) are better for kitchen islands due to stability compared to narrow units. In addition to height, consider depth – seating area countertops should have enough depth (at least 40-50 cm (16-20 inches) overhang) without restricting movement space.
What does your space look like? Particularly the position of the kitchen island and surrounding pathways are important for planning.
TUELBA schrieb:
What does your space look like? Especially the position of the kitchen island and the surrounding pathways are important for planning.I also think that’s very important. At first, I had similar questions and was a bit unsure whether my kitchen had enough space for an island with seating without everything feeling too cramped. I roughly marked the kitchen area and made sure there was still enough clearance behind the stools (at least 90 cm (35 inches)).
What helped me as well were flexible stools that can easily be pushed under the countertop. This makes the kitchen island feel practical and very open during the day. I also considered for a while whether to choose a standard seat height (about 90 cm (35 inches)) or bar height. The bar height is good for creating a clear separation, but I was a bit concerned it might become uncomfortable to sit on for longer periods.
In the end, I went with bar height, but for me, it feels more like a quick coffee spot rather than a place to sit for long conversations. You should think about how you want to use the seating area.
All in all, having an island like this is a great feature! 🙂
Bubalazs schrieb:
My main question is which base cabinets are best suited, how I can extend or adjust the countertop, and any tips for securely fastening it when aiming for counter height or bar height.Hello Bubalazs,
I’m happy to add some practical recommendations:
- For a kitchen island with an integrated seating area, Metod base cabinets with higher stability are particularly advantageous, ideally with side panels made of wood or metal to support the weight of the countertop.
- You can buy the countertop at Ikea in standard lengths or have it cut to size; for the seating area, use a countertop made of durable material such as solid wood or laminate, with a thickness of at least 3–4 cm (1¼–1½ inches).
- If you install a higher seating surface (bar height 104–110 cm (41–43 inches)), build an additional substructure under the countertop using wooden battens or metal profiles, preferably with reinforced angle brackets attached to the sides of the base cabinets.
- To protect the edges, especially on overhangs, I recommend using an edge strip or sturdy edge protection.
- If you plan to use stools with backrests, allow enough legroom (at least 30 cm (12 inches) under the countertop).
Practical tip: If possible, make the seating area detachable or modular so you can more easily make changes later.
If you like, I can also send you a list of recommended Ikea parts and possible extensions.
