ᐅ IKEA METOD: How to Build Kitchen Cabinets for Accessible Kitchens?
Created on: 25 Oct 2020 08:32
LAUKAR
LAUKAR
25 Oct 2020 08:32
I am currently planning to build an accessible kitchen using the Ikea METOD system and am looking for practical tips and guidance on how to design kitchen furniture that meets accessibility requirements.
I am particularly interested in adjustments regarding handle heights, cabinet depths, and the use of pull-outs that are practical for people with limited mobility or wheelchair users.
What is the best approach to ensure planning, measurements, and functionality are implemented accurately and realistically? Are there specific solutions within the METOD range that are especially suitable?
Perhaps someone has experience combining IKEA METOD with accessible design or knows useful advice for selecting components to create a user-friendly kitchen.
Looking forward to your feedback and thank you in advance!
chen67
25 Oct 2020 09:46
Hello LAUKAR,
Your question is very relevant, especially since IKEA METOD is primarily designed for standard kitchens, but with a bit of creativity, you can definitely achieve a lot. For barrier-free kitchens, it is important that countertops and cabinets are as flexible and accessible as possible.
From my own experience, I recommend using tall cabinets mounted at different heights so they are easily reachable for all users. I also find drawers instead of doors to be excellent, as they are easier to access—no bending or deep reaching needed.
By the way, METOD from IKEA offers special comfort handles that are easy to operate even with limited hand mobility—really simple and effective! 😉
If you like, I can share a few more practical tips on making the kitchen even more barrier-free.
Ianlau
25 Oct 2020 10:28
Hello LAUKAR,
I can understand your question well, as accessible kitchen planning is often more complex than it initially seems.
With IKEA METOD, the base cabinet heights can generally be adjusted (for example, by changing the height of the legs or using a tall cabinet system) to ensure optimal accessibility. Drawer systems can also be integrated and combined with suitable assistive handles.
It is important to determine the worktop height individually so that it is comfortable not only for wheelchair users but also for people with mobility impairments. For example, countertop dimensions can be adjusted in width or depth to allow enough space to move underneath.
I recommend taking precise measurements during planning and checking IKEA products for options to adjust the depth, height, or cabinet types. There are also special accessories, such as handle bars, that are particularly suitable for accessible kitchens.
If you need more details, I am happy to help!
Ernesto
25 Oct 2020 11:15
Hello LAUKAR,
If you want to design METOD kitchen cabinets to be barrier-free, you need to plan very carefully and consider some technical details.
First of all: barrier-free means not only accessible but also independently usable – for different mobility impairments. For wheelchair users, the main point is that the countertop must be wheelchair accessible underneath. To achieve this, METOD base cabinets can partially be replaced by open spaces or special underframe solutions.
The standard depth of base cabinets (60 cm (24 inches)) can be problematic for wheelchair users because this depth often makes it difficult to get close enough. In this case, modifications might be necessary, such as shorter kickboards or a reduced plinth, depending on the available space.
Another point: soft-close drawers are preferable because smooth operating mechanisms make handling easier. Also, handle rails that run lengthwise offer advantages compared to small handles.
Could you please clarify whether the kitchen is intended specifically for a wheelchair user or if other impairments should also be taken into account? Then I could provide more targeted advice for the specific planning.
LAUKAR
25 Oct 2020 11:57
Ernesto schrieb:
Could you please clarify whether the kitchen is intended specifically for a wheelchair user, or if other mobility restrictions should also be taken into account? That way, I can provide more targeted planning advice.
Thank you for asking, Ernesto – very important!
The kitchen is primarily designed for a wheelchair user who has varying levels of mobility. That means sometimes relying on a wheelchair and at other times experiencing general mobility difficulties.
Therefore, the kitchen needs to be as multifunctional and flexible as possible. Work surfaces should be wheelchair-accessible, cabinets easily reachable, and drawers and cabinet doors should be easy to operate.
Specifically, are there any special METOD modules or accessories that allow for easy modification of base cabinets (e.g., reduced depth, open sections, special handles), and what about the stability and safety of such alterations?
Danabla
25 Oct 2020 12:35
LAUKAR,
Regarding accessible kitchens, yesterday I spent some time studying the METOD system. IKEA itself does not offer specific accessible modules, but there are definitely ways to adapt METOD to ensure high functionality.
- The installation height is important: the worktop height can be raised to about 85 cm (33 inches) to allow wheelchair clearance underneath.
- For wheelchair-accessible areas, base cabinets can be omitted by leaving at least 68 cm (27 inches) depth and 80 cm (31 inches) width free.
- Drawers/pull-outs are preferable to doors, as they are easier to access.
- Handles: long bar pulls or handle strips make operation easier.
Regarding stability: The stability is not affected when adjusting the plinths, as long as no load-bearing elements are removed. It is important not to weaken any load-bearing walls or structural supports.
Recommendation: If standard METOD components don’t fit all requirements, additional adjustable shelves or wheelchair-accessible shelving units can be installed modularly.
Customizing the countertop (preferably using durable materials) is worth considering to perfectly accommodate the required clearances.
