ᐅ Ikea Metod: How do I attach countertops to different types of walls?
Created on: 12 Apr 2023 09:23
Nicotar40
Hello everyone, I am currently planning the installation of an Ikea Metod kitchen and facing the challenge of securely and permanently fixing the countertops to different types of walls. Specifically, I am dealing with three different wall types: load-bearing concrete walls, drywall (plasterboard) walls with a substructure, and walls partially covered with tiles. My question is: which fixing methods and materials are best suited to securely attach an Ikea Metod countertop without causing damage to either the wall or the countertop? I am also interested in how to optimize fastening on drywall (plasterboard) walls to avoid overloading any load-bearing function, and the best approach for tiled walls to prevent tiles from cracking. For each type of wall, I would appreciate advice on suitable anchors, screws, and possibly additional brackets or batten supports. Thanks in advance for your tips and experience!
farje schrieb:
I always recommend starting by drilling slowly with a small carbide-tipped drill bit, without hammer action, to create a guide for the larger bit.I agree with that. Additionally, sometimes covering the drilling spot with painter’s tape helps prevent the drill bit from slipping and reduces the risk of cracks.
Regarding drywall: To securely support the countertop, I have had good results using metal toggle bolts, which provide strong anchoring in hollow walls. Combined with a wooden support batten, this creates a very stable solution.
Nicotar4013 Apr 2023 09:55Many thanks again to everyone who has helped so far! Here is a summary of my plan:
- Concrete walls: Use heavy-duty anchors and appropriate screws, pre-drilled with a hammer drill.
- Drywall (plasterboard) walls: Attach a wooden batten 40-60 mm (1.5–2.5 inches) wide and 20-30 mm (0.8–1.2 inches) thick firmly to the wall framing. Use anchors and fasteners designed specifically for hollow walls (metal toggle bolts or similar).
- Tiled wall: Pre-drill with a small carbide-tipped drill bit, optionally using painter’s tape to protect the surface, then slowly drill with a masonry bit. After drilling, seal the grout lines with silicone.
Is there anything else I should definitely consider when installing the Ikea Metod countertops? For example, regarding fastening points under the countertop or things to avoid to prevent the countertop from chipping or warping?
Your summary is good. Additionally, I recommend:
- Make sure to distribute the fastening points as evenly as possible along the countertop, at least every 40-50 cm (16-20 inches).
- Use only the assembly parts recommended by Ikea to ensure a secure connection with the Metod carcasses.
- Avoid overloading the edges; if necessary, install additional supports or brackets, especially for longer countertop sections.
- Check that the countertop is adequately ventilated, particularly if it is made of moisture-sensitive material.
This way, you can effectively prevent warping and breakage.
