ᐅ Ikea Metod: How do I attach countertops to different types of walls?
Created on: 12 Apr 2023 09:23
Nicotar40
Nicotar40
12 Apr 2023 09:23
Hello everyone, I am currently planning the installation of an Ikea Metod kitchen and facing the challenge of securely and permanently fixing the countertops to different types of walls. Specifically, I am dealing with three different wall types: load-bearing concrete walls, drywall (plasterboard) walls with a substructure, and walls partially covered with tiles. My question is: which fixing methods and materials are best suited to securely attach an Ikea Metod countertop without causing damage to either the wall or the countertop? I am also interested in how to optimize fastening on drywall (plasterboard) walls to avoid overloading any load-bearing function, and the best approach for tiled walls to prevent tiles from cracking. For each type of wall, I would appreciate advice on suitable anchors, screws, and possibly additional brackets or batten supports. Thanks in advance for your tips and experience!
Paunon
12 Apr 2023 09:45
For concrete walls, simply use heavy-duty anchors to securely hold the countertop. For drywall, I recommend cavity anchors to ensure load-bearing capacity. For tiled walls, it is best to use hammer anchors with appropriate drill bits to avoid cracks.
Ramon4
12 Apr 2023 10:12
Hello Nicotar40, I completely understand your question because the stability of the countertop is very important for practical use later. For each wall type, I recommend:
- Concrete: Be sure to use high-quality heavy-duty anchors and suitable screws that are at least 6 mm (0.24 inches) thick. If possible, pre-drill with a hammer drill.
- Drywall: Use special metal anchors or toggle bolts, which hold the board better. It is also advisable to attach a wooden strip behind the drywall for additional reinforcement.
- Tiles: Drill slowly with a masonry bit, preferably using a low-impact or percussion drill function carefully. Then use anchors with a slightly larger diameter to prevent cracking.
If you want to additionally secure the countertop with angle brackets, also fix them to the wall using suitable anchors.
Nicotar40
12 Apr 2023 14:37
Thanks in advance for the initial tips! A quick question: Regarding drywall and additional wooden reinforcement – what is the ideal depth for this batten, and what is the best way to fix it? I want to avoid stress or damage later caused by loads from the countertop. Is it better to screw the batten directly to the substructure or to leave a gap to the wall? And for tiled walls: Are there any recommendations for sealing joints after drilling to prevent moisture damage?
RETRAVIS
12 Apr 2023 15:08
Nicotar40 schrieb:
Regarding drywall and additional wood reinforcement – what is the ideal depth for this wooden batten, and what is the best way to fix it?
The wooden batten should be at least 40 to 60 mm (1.5 to 2.5 inches) wide and 20 to 30 mm (0.8 to 1.2 inches) thick to provide sufficient stability. It should be fixed directly to the load-bearing substructure or wall studs behind the drywall, using long screws (at least 6 cm (2.4 inches)) driven through the drywall.
Nicotar40 schrieb:
Is it better to screw the batten directly to the substructure or leave a gap between the batten and the wall?
Direct contact with the substructure is preferable because this allows the load to be transferred directly and prevents movement caused by gaps.
Nicotar40 schrieb:
And for tiled walls: Are there recommendations for sealing joints after drilling to prevent moisture damage?
Yes, after drilling, the drilled area should be sealed with an appropriate silicone or acrylic sealant. This protects against moisture and prevents subsequent damage to the masonry or the backside of the tiles.
farje
12 Apr 2023 18:41
Ramon4 schrieb:
Tiles: Drill slowly with a masonry drill bit, preferably with low impact or using the hammer drill function cautiously.
I slightly disagree here: hammer drilling directly through tiles is very risky. Without the proper technique, the tiles tend to chip easily. I always recommend first drilling slowly without hammer action using a small carbide-tipped drill bit to create a guide hole for the larger bit. Only once the tile surface is penetrated should the masonry drill bit and hammer function be used carefully.
In general: the more delicate the tile, the more carefully and at a lower speed it should be drilled.
Does anyone have experience with special tile drill bits or drilling aids that reliably help avoid damaging tiles?
