Hello everyone, I am currently planning to paint my Ikea Metod kitchen fronts myself to customize them according to my interior style. I want to achieve durable results that can withstand the everyday demands of a kitchen.
My questions are: What pretreatment is especially recommended for fronts made of plastic or wood chipboard to achieve a smooth and adhesive paint surface? Which types of paint have proven effective – in other words, is a water-based acrylic paint sufficient, or would it be better to use a specialized synthetic resin paint?
I am also interested in which methods (brush, roller, spray can, or compressor spray gun) you have had good experiences with, particularly for neatly painting edges and possibly profile surfaces.
Any tips on drying times, intermediate sanding, and possible sealing are also welcome. Thanks in advance for your suggestions!
First, sand the fronts thoroughly, preferably with 220-grit sandpaper.
Then, dust off carefully. For Rompa plastic fronts, a two-component (2K) synthetic resin paint is best, as it is very durable.
For painting, I would recommend spray paint, as it provides the cleanest finish. Don’t forget to do an intermediate sanding with fine sandpaper.
neoren schrieb:
For Rompa plastic fronts, two-component (2K) polyurethane lacquer is the best choice because it is very durable.I always wonder if the effort is really worth the result. Ikea fronts are so affordable that I’d rather spend a few extra euros on new fronts than spend ages on the painting process. Sure, custom painting sounds appealing, but in practice very few people can achieve a finish without dust inclusions and unevenness.
Honestly: who among you has ever done this and ended up with a truly showroom-worthy result? Or do you just end up spending hours on craftsmanship that goes unnoticed because everyday use destroys the surface?
flo-Theres27 Jul 2021 07:18I have personally painted several Metod fronts and can recommend the following:
- First, sand the fronts with 400-grit wet sandpaper to slightly roughen the smooth surface without damaging the material.
- Then clean the surface with a degreaser (isopropanol or an equivalent).
- Use a high-quality water-based acrylic paint that is suitable for DIY projects and provides good adhesion.
- It is best to paint using a spray gun or a fine foam roller. Brushes tend to leave visible marks.
- Always do a light sanding between paint layers (e.g., 600-grit).
- Finally, seal with clear lacquer, especially if the fronts are close to water or frequently handled with kitchen utensils.
Important: A dust-free environment and sufficient drying time—at least 12 hours per coat—significantly improve durability.
This is why using 2-component (2K) synthetic resin paint is not recommended for DIY projects, as it is often more toxic and harder to apply.
ANMARCOS schrieb:
Honestly: How many of you have done this in a way that the result was really presentable? Or do you just end up spending hours on craftsmanship that no one sees because daily use damages the surface?I understand what you mean – the effort should not be underestimated. Before starting my project, I also questioned multiple times whether the effort was worth it. For me, it was especially important to achieve a unique look that you don’t get from Ikea.
Besides the professional tips in this thread, I can only recommend spending plenty of time sanding and applying the finish in dust-free conditions. The surface can indeed be sensitive, but with clear lacquer and careful handling, it holds up surprisingly well.
If you’re unsure, you could also finish individual cabinet fronts as a “test” and see if the result meets your expectations. This way you can avoid major disappointment.
