ᐅ Ikea METOD: How can I modify kitchen cabinets to be child-friendly?
Created on: 4 Jun 2017 09:13
CHENNO
CHENNO
4 Jun 2017 09:13
Hello everyone, I am currently working on a project where I want to make the Ikea METOD kitchen cabinets more child-friendly. The challenge is to maintain storage space and functionality while making sharp corners, edges, and hard-to-reach areas safer for small children. I am especially interested in which modifications work best for the classic METOD cabinets and fronts to prevent injuries, and how to make handles, hinges, or internal components safer. It would also be great to get tips on how to modify kitchen furniture so it can be easily disassembled or adjusted as the children grow older. Does anyone have experience or specific suggestions, perhaps including suitable materials or special child safety add-ons? I appreciate any advice!
NUGRANT
4 Jun 2017 10:37
Super interesting question! 😄 The METOD kitchen cabinets are really great, but of course, when you have small children around, it quickly gets tricky. I think the first step is to really soften all sharp corners and edges. You can easily use self-adhesive corner protectors, which come in various degrees of hardness. And please change the handles! Remove them and install rounded or even recessed handles instead. These are much more child-friendly.
CHENNO schrieb:
The challenge is that on one hand I want to maintain storage space and functionality, but at the same time make dangerous corners, sharp edges, and hard-to-reach areas safer for small children.
Exactly, that’s what my brother did as well. Additionally, I think a magnetic or push-to-open system is great, so there are no handles for kids to bump into. The hinges can also be fitted with soft-close mechanisms to prevent fingers from getting pinched. By the way, I also locked some lower cabinets with a door and placed the items higher up. This way, the kids can’t reach the contents directly, which makes it even safer. Good luck with your project! You can do it! 👍
FABIAN_DEO
5 Jun 2017 14:06
Good approach from you, CHENNO—modifying the METOD kitchen to be child-friendly is definitely doable, but it comes with some challenges. Technically, the focus is on protecting against pinch points, avoiding sharp edges, and limiting access to hazardous areas.
First, I would recommend replacing the cabinet fronts with scratch- and impact-resistant versions, such as using ABS edging on the doors, which is rounded and durable. Replace the original handles with so-called “soft-edge handles” or handle strips that have no sharp corners. Additionally, special damping systems on the hinges are important. IKEA offers, for example, bumpers to retrofit that prevent doors from slamming shut too quickly.
For child safety on the drawers, installing magnetic child locks inside the drawers is advisable—you need to ensure they are compatible with METOD and take the mounting profiles into account.
Another key point: For the lower cabinets, you can install double drawers—a shallower top drawer for frequently used, child-safe items and a deeper bottom drawer that remains locked. This way, you can limit access effectively.
Regarding future adaptability, I recommend installing all safety devices reversibly and without damaging the furniture (for example, by screwing to frame parts instead of using permanent adhesive) so the kitchen can grow with your needs.
Finally, two questions: How old are the children you are doing this for? And are you planning more safety measures for the preparation areas, or mainly for the storage compartments? This makes a difference in how you implement it.
popodi
5 Jun 2017 17:44
Hey CHENNO, great idea to upgrade your kitchen and also think about the little whirlwinds! 😎 From my experience, IKEA is fun for this because the modules are so flexible.
A small tip from me: look for soft edge protectors for the countertops, available in foam or rubber, which you can quickly roll on. This helps prevent nasty bumps right away.
FABIAN_DEO schrieb:
For child safety on drawers, it’s recommended to install magnetic child locks inside the drawers – you need to make sure they are compatible with METOD and consider the mounting profiles.
You can also find ones with a small twist knob, so you don’t have to search for the magnet first. My kids always tried to figure it out, and I find it better when it’s a bit easier for parents to operate but harder for the little ones.
And yes, handles are a classic – we removed them completely and went with a handle profile! It not only looks better with the design but is also less prone to damage. A workshop with the kids before remodeling is definitely fun to find out what they like and what they don’t! Good luck and keep us updated!
Johnnybe
6 Jun 2017 08:22
Short and practical:
- Replace handles with flush handle strips
- Use self-adhesive corner protectors
- Install soft closers for flap doors
- Fit child safety locks inside the lower drawers
- Apply edge protectors to worktops
This way, you’re on the safe side.
