Hello everyone, I recently installed a kitchen using the Ikea Metod system, but I have the issue that the doors do not close smoothly and quietly. Especially with the larger doors, there is often a loud slam, which is not only annoying but can also put stress on the hinges and doors over time. Now I am wondering what options are available to make the doors close gently and quietly. Are there any special damping systems from Ikea that I can retrofit, or alternative solutions that work well with Metod? I would really appreciate any experience or tips, as I am looking for a durable and practical solution. Thank you in advance!
Good morning, I would like to go into more detail because the solution is not always just about replacing the hinges. Ikea actually offers soft-close hinges that can be installed quite easily without removing the entire door. However, it is important to know which hinge model you have installed on your Metod cabinets, as different soft-close components come with different versions.
If you have standard clip-on hinges, the soft-close springs can usually be retrofitted. For older models, it may sometimes be necessary to purchase completely new hinges.
Additionally, door size and weight also affect the closing behavior: for particularly heavy doors, it can help to adjust the hinges so they are optimally balanced.
One lesser-known alternative is so-called "buffer dampers" (usually small silicone or rubber buffers on the cabinet sides). These minimize impact but are not a replacement for soft-close hinges and rather serve as an additional feature.
A question for you: What kind of hinges have you installed, and how heavy or large are your doors? That could make the advice more precise.
Palenar schrieb:
One question for you: Which hinges did you use, and how heavy or large are your doors? That could make the recommendation more precise.Thanks for the detailed answer! I’m using the classic clip-on 110° hinges from Ikea, and the doors are about 60cm (24 inches) wide and 70cm (28 inches) high, medium weight, probably around 8–10kg (18–22 lbs). So far, I don’t have any soft-close mechanism, just the standard hinges. Are there exact soft-close retrofit parts for these models that can simply be clipped on? And if so, does that affect the door adjustment or alignment in any way that I should be aware of?
Yes, there are suitable soft-close inserts available for clip-on hinges. You can simply insert them into the existing hinges. After installation, you should readjust the door, as the soft-close mechanism slows it down slightly differently. Make sure the installation is precise, and then it will work very well.
Hello everyone, I’ve had similar experiences and would like to add the following: The soft-close retrofit kits for Ikea Metod clip-on hinges are quite reliable and can often be installed without complicated tools. It is important to make some minor adjustments to the door afterwards, as the damping slightly changes the door’s closing pressure.
If the soft-close function is not sufficient, there are also damper strips (usually made of plastic or rubber) that can be attached to the cabinet frame to provide additional cushioning. However, this is an extra retrofit option for users who want an extremely quiet operation.
A major advantage of soft-close hinges is that they protect the furniture, especially on frequently used doors, and reduce everyday noise. If anyone has further questions about the installation, I’m happy to help.
