ᐅ Ikea Metod: How can I clean glass cabinet fronts without scratching them?
Created on: 26 Oct 2020 08:37
letunay
I have been using the IKEA Metod kitchen cabinets with glass fronts in my new kitchen for some time now. My question is about maintenance: I would like to know how to clean these glass fronts without scratching them or causing any dullness or damage. When I use regular all-purpose cleaners, I often feel like the glass becomes slightly dull or that small scratches might appear after several uses. Does anyone have tried-and-true methods or cleaning products that can be used safely to keep the glass fronts clean while protecting the surface? I would appreciate any tips on cleaning tools, techniques, or suitable substances.
How do you keep your Metod glass fronts clean and scratch-free?
barda6
27 Oct 2020 09:03
I would avoid using vinegar water on metal frames, as it can damage the protective coating over time. It is better to use an acid-free glass cleaner and a microfiber cloth, which is completely sufficient.
joroti
28 Oct 2020 14:17
letunay schrieb:
What do you think about glass cleaners with ammonia or vinegar water?
Cleaners containing ammonia are much stronger and can damage surfaces if used frequently. Vinegar water is milder but not ideal for aluminum frames either. It’s better to use pH-neutral glass cleaners or simply water and a microfiber cloth.
mifra
29 Oct 2020 19:50
Additionally, I would like to mention that the glass fronts of the Metod series are made of real glass. Therefore, they are generally durable but not immune to microabrasive damage. This means that
- harsh or abrasive cleaning agents
- scouring pads
- coarse woven cloths
should be avoided.
Furthermore, regularly used vinegar water can potentially corrode or dull the aluminum profiles, so it is recommended to clean the glass panes separately with mild cleaning agents and minimize moisture contact with the frames.
