ᐅ Ikea Metod: How can I clean glass cabinet fronts without scratching them?
Created on: 26 Oct 2020 08:37
letunay
letunay
26 Oct 2020 08:37
I have been using the IKEA Metod kitchen cabinets with glass fronts in my new kitchen for some time now. My question is about maintenance: I would like to know how to clean these glass fronts without scratching them or causing any dullness or damage. When I use regular all-purpose cleaners, I often feel like the glass becomes slightly dull or that small scratches might appear after several uses. Does anyone have tried-and-true methods or cleaning products that can be used safely to keep the glass fronts clean while protecting the surface? I would appreciate any tips on cleaning tools, techniques, or suitable substances.
How do you keep your Metod glass fronts clean and scratch-free?
fiman
26 Oct 2020 09:12
Use a microfiber cloth and lukewarm water. Do not use abrasive cleaners or rough sponges; this is the most important point.
mifra
26 Oct 2020 10:04
For scratch-free cleaning of the IKEA Metod glass fronts, I recommend the following procedure:
- Use only a soft, lint-free microfiber cloth.
- Dampen the cloth with clear tap water or a mildly diluted alcohol-based glass cleaner.
- Avoid abrasive cleaning agents, scouring pads, or harsh chemical cleaners, as these can damage the surface.
- Gently wipe the glass fronts in circular motions.
Additionally, it is helpful to polish the glass fronts after cleaning with a dry microfiber cloth to prevent streaks. This keeps the surface clear and free of micro-scratches.
gipifa
26 Oct 2020 11:19
Great question! I always use only very mild products, and the results are really excellent! If you keep the fronts clean, remember to regularly wipe them down with a lightly dampened microfiber cloth. This keeps them shiny and scratch-free! Stick with it; it definitely pays off! 🙂
letunay
27 Oct 2020 07:42
mifra schrieb:
Avoid abrasive cleaners, scouring pads, or harsh chemical cleaning agents, as they can damage the surface.
Thank you, that is really helpful! What do you think about glass cleaners containing ammonia or vinegar solutions? Could using vinegar solutions cause any long-term damage to the glass or the surrounding frames? The Metod fronts usually have aluminum frames, and I want to avoid risking rust or discoloration from cleaning.
Demetrius
27 Oct 2020 08:27
I used to try vinegar water as well, but I felt that it eventually caused slight discoloration on my aluminum frame. Since then, I prefer to use a mild glass cleaner without ammonia. This feels safer to me, and the glass fronts still look great even after months.
In general, I think it’s important to handle such materials carefully and avoid harsh chemicals. Maybe you could test the vinegar water first on an inconspicuous corner?
