ᐅ Cleaning and Maintaining Ikea Metod Glass Fronts Without Streaks
Created on: 16 Jul 2023 08:17
AnnetanHello everyone,
I have glass fronts on my IKEA Metod kitchen that I really want to clean without streaks. So far, I haven’t been satisfied with the results because there are always unpleasant smudges or streaks left behind, even though I’ve tried different glass cleaners and used cloths with varying degrees of softness. Therefore, my question to the forum is: Which cleaning methods and care products work best to get the glass fronts of the IKEA Metod kitchen truly streak-free and to maintain them optimally over the long term? Are there any special tips to consider for this material in order to avoid damaging the surface while still effectively removing typical fingerprints or water spots? I’m looking forward to your experiences and advice – thanks in advance!
Hello Annetan,
to clean your Ikea Metod glass fronts streak-free and maintain them optimally, I recommend the following procedure:
- First, use a microfiber cloth that is dust- and lint-free.
- Apply a solution of warm water and a little mild dish soap to the cloth—never spray directly onto the glass surfaces.
- Wipe the fronts thoroughly to remove grease and coarse dirt.
- Then wipe again with clean, clear water.
- For a streak-free finish, the best choice is a glass cleaner without ammonia or alcohol, as these can damage the glass over time.
- Important: Use a dry microfiber cloth in a crosswise motion without pressing to dry.
A common mistake is spraying the cleaner directly on the glass, which leaves drops that dry and cause streaks. Also, avoid using abrasive materials to prevent scratches.
For maintenance, I recommend cleaning the glass surfaces regularly and wiping off fingerprints immediately. If you like, I can also suggest a natural alternative to chemical glass cleaners.
I hope this helps you!
For the best care of Ikea Metod glass fronts, it is essential to avoid aggressive cleaners. The same applies to the cloth: do not use paper towels or abrasive cloths, as they can cause scratches. My recommendation for stubborn stains is to use a mixture of water and a small amount of rubbing alcohol (isopropanol), which helps remove streaks quickly. Afterwards, wipe again with clean water and dry by polishing with a soft cloth.
Annetan schrieb:
Which cleaning methods and care products work best to get the glass fronts of the Ikea Metod kitchen truly streak-free and to maintain them optimally over time?One more tip for maintenance: You can protect the surfaces with a glass sealant, originally designed for car windows. It helps reduce water and dirt adhesion. However, make sure to test it first on an inconspicuous spot!
JONSON schrieb:
My recommendation for stubborn stains is to use a mixture of water and a splash of rubbing alcohol (isopropanol).I think that’s a helpful suggestion. Rubbing alcohol or isopropanol is generally a better choice than harsher alcohols because it evaporates without leaving residue.
