ᐅ How to Make Ikea Metod Drawers Close Quietly and Smoothly Without Much Effort
Created on: 26 Sep 2024 07:34
BESERKAN
I recently installed an Ikea Metod kitchen and am generally satisfied with the drawers. However, I’ve noticed that the drawers don’t close very quietly or smoothly, which can be a bit annoying with daily use. It’s important to me that the closing is soft and damped without loud slamming, but I don’t want to undertake major work, such as complicated retrofitting or buying expensive special parts.
My question is: What simple and cost-effective options are there to make the Ikea Metod drawers close quietly and smoothly? Are there any proven small tricks or easy additions that noticeably improve the result? I’m also open to tips on how to adjust or optimize the existing drawer slide systems to reduce noise.
I’m looking forward to practical solutions without extensive DIY efforts. Thanks in advance!
GiRoyce
28 Sep 2024 15:42
I would like to add a few pointers since this topic concerns quite a few customers.
tra_nina schrieb:
Checking and, if necessary, readjusting the guide rails using the designated adjustment screws.
Exactly, the key to fine-tuning often lies in proper adjustment. When adjusting, I recommend ensuring that the drawer and guide rail are aligned perfectly parallel. Small deviations can cause more noise and uneven damping.
juMira46 schrieb:
Sometimes the drawer is pushed in a little crooked
That’s also a very good point. In this case, the drawer should be securely fixed, and the rails checked before installation. Some users forget to inspect the rails before installing, which can significantly affect the soft-close function.
Additionally, I recommend checking the sliding bearings for wear in older drawers. If these are worn or damaged, the damper may not operate correctly. In such cases, replacing the rails might be worthwhile.
For all of you: a bit of patience with fine-tuning and cleaning often achieves the desired effect without expensive investments or major modifications.
If you have specific questions about certain models or configurations, I’m happy to assist.
