ᐅ How to Make Ikea Metod Drawers Close Quietly and Smoothly Without Much Effort
Created on: 26 Sep 2024 07:34
BESERKAN
BESERKAN
26 Sep 2024 07:34
I recently installed an Ikea Metod kitchen and am generally satisfied with the drawers. However, I’ve noticed that the drawers don’t close very quietly or smoothly, which can be a bit annoying with daily use. It’s important to me that the closing is soft and damped without loud slamming, but I don’t want to undertake major work, such as complicated retrofitting or buying expensive special parts.
My question is: What simple and cost-effective options are there to make the Ikea Metod drawers close quietly and smoothly? Are there any proven small tricks or easy additions that noticeably improve the result? I’m also open to tips on how to adjust or optimize the existing drawer slide systems to reduce noise.
I’m looking forward to practical solutions without extensive DIY efforts. Thanks in advance!
KNUTGI
26 Sep 2024 09:15
BESERKAN schrieb:
My question is: What are some simple and as cost-effective as possible ways to make the Ikea Metod drawers close quietly and smoothly?
Hey, great question! 😄 I had the same issue with my drawers slamming shut instead of closing gently. My personal tip: try adjusting the soft-close runners from Ikea. You can move the small clips on the sides of the drawers slightly to create more resistance, which helps the drawer close more slowly.
If that’s not enough, sometimes soft adhesive pads on the inside of the drawer can help. Nothing big, but the little cushion at least softens the closing a bit.
And don’t worry: no complicated installation or expensive modifications needed. You can do this easily in 5 minutes. Oh, and always keep the runners clean—dust can cause problems too!
Filippo
26 Sep 2024 11:52
BESERKAN schrieb:
Any tips on how to adjust or improve the already installed sliding systems to minimize noise would be appreciated.
Here is a more detailed explanation of the mechanism: Ikea Metod drawers typically use runners and soft-close dampers, which are marketed as soft-close but can still be noisy depending on the load and adjustment.
For adjustment:
- Fully extend the drawer and look at the runner: there are small plastic dampers at the back that slow down the drawer. These can be slightly repositioned to change the damping force.
- Sometimes, the height of the drawer can be adjusted on the sides with a small adjustment screw.
- Treat the runner bearings and tracks with silicone spray to make the sliding smoother.
- Adding felt tape or thin foam strips to the back panel of the drawer can reduce impact noise.
If the drawers are set very tightly, it is advisable to slightly loosen the runners, as too much tension can also cause loud banging sounds.
Interesting: some Ikea customers completely replace the original soft-close systems with third-party soft-close solutions, but this requires considerable effort. For a small effort, adjusting the original systems is often already very effective.
juMira46
26 Sep 2024 13:07
KNUTGI schrieb:
My personal tip: Just try adjusting the soft-close rails from Ikea more precisely.
Oh yes, adjusting them is really worth gold! 😄 I simply removed the drawer, cleaned the runners inside thoroughly, and after that the difference was clearly audible – they suddenly slide very smoothly.
Another simple tip from me: Sometimes the drawer is inserted a bit crooked, which can cause the “slamming” noise. A careful, precise installation with some patience when sliding it in works wonders.
For an even smoother closing, I also use these small self-adhesive dampers that you can attach instead of the regular rubber buffers – they cost very little and you notice the difference immediately.
Sometimes all it takes is a little care and attention during installation and cleaning.
tra_nina
27 Sep 2024 08:44
To add a structured and objective perspective on the topic: Ikea Metod drawers generally feature a soft-close function that uses damping mechanisms to reduce noise when closing. However, there are differences in quality and variations in installation that can lessen this effect.
Pragmatic solutions:
- Check and, if necessary, readjust the drawer slides using the built-in adjustment screws.
- Clean the slides from dust and dirt, as these increase friction and noise.
- Attach optional rubber or felt pads inside the drawer to cushion impact.
- Monitor the load: Overfilled drawers strain the mechanism and can reduce the effectiveness of the dampers.
A combination of these measures usually results in noticeably quieter and smoother operation. In most cases, extensive modifications or component replacements are not necessary.
BARSAN
27 Sep 2024 12:18
Recommendation: Thoroughly clean the original soft-close rails, and optionally apply a small amount of silicone spray. Then, if possible, slightly adjust the dampers at the back of the rail. Self-adhesive felt or rubber pads on the back of the drawer further reduce noise.
