ᐅ IKEA Metod Installation: How Do I Accurately Measure the Width of My Cabinets?
Created on: 5 Mar 2024 08:13
pefomuI am currently preparing to assemble my new IKEA Metod base cabinets and want to measure the width of each cabinet as precisely as possible before starting installation. My question is: What is the best and most reliable way to measure the width of my Metod cabinets, especially considering that there may already be cutouts for fittings or fasteners? Which measurement points should I focus on to ensure proper fit and avoid installation issues later on? Any tips or experiences with this step for Metod cabinets would be very helpful!
Good morning! In general, it is important to check the dimensions of each cabinet before assembly. It is best to lay the cabinet flat and measure precisely from the outside left edge to the right edge using a metal tape measure. It is advisable to take measurements at several points (top, middle, and bottom) rather than just one, to identify any manufacturing tolerances. Depth is also an important factor—do not overlook it. If you already have wall mounting brackets or holes in the cabinet, you should take these into account during measurement, as they can affect the usable internal width.
For precise width measurement, I recommend the following procedure:
- First, place the cabinet carcass on a level surface, ideally on the floor in your assembly area.
- Use a good quality steel tape measure to measure the outer edges at the top, middle, and bottom. Take the smallest value.
- Also check the width inside, right next to any possible cutouts, because depending on whether you need to integrate pipes or electrical cables, the space there can be critical.
- Sometimes the measurements differ slightly due to manufacturing tolerances; this can happen with Metod units.
- It’s best to use 2-meter (6.6 feet) steel tape measures, as they stretch minimally and are precise.
Please also specify whether you are installing standard widths or preparing custom sizes, as this can affect accuracy. Another question: Do you want to measure the widths for room planning or directly for installation steps?
Dilen schrieb:
Please also indicate whether you are installing standard widths or preparing custom dimensions, as this can help with accuracy. Thank you for asking, Dilen – I am assembling standard Metod cabinets (60 cm (24 inches) wide). But it is good to know that manufacturing tolerances are common. My main concern is the installation on site, for example where connections for the sink or stove will be made, and I want to avoid any issues caused by incorrect dimensions.
How exactly should I proceed when aligning the cabinets to the wall? Are mounting screws relevant when measuring the width?
In this case, you should always measure the width on the outside of the cabinet body, as the mounting screws and brackets can affect the internal dimensions and final alignment. It is important to:
- Hold the tape measure straight, never at an angle
- Take measurements at least in three places (top, middle, bottom) and use the smallest value for planning
- Consider connections, wall clearances, and attachment points on the cabinet body, especially for water and electrical connections
- When installing, tighten the mounting screws only after the final measurement to allow for small adjustments
This approach ensures the highest possible accuracy and prevents fitting issues later on.
