ᐅ Ikea Metod alternative legs – can they be shortened? Experiences
Created on: 4 May 2015 11:43
madroxHello,
I would like to replace my kitchen with a Metod kitchen in the next few years.
Unfortunately, I need to access my kitchen windows, which are 88 cm (35 inches) high, but they are 4 cm (1.6 inches) too low for Metod cabinets.
So, instead of legs that are 8-9 cm (3-3.5 inches) high, I would need legs that are around 4 cm (1.6 inches) high.
Are there any alternative legs available for purchase that would fit?
Alternatively, has anyone made their own legs or a base frame?
Thank you
Thank you
IKEA-Experte4 May 2015 15:50Hello,
is the 88 cm (35 inches) measured up to the open window or the window sill?
The lowest height for feet that I know of is 55 mm (-5 mm / 20 mm) high. If the floor is not higher at a relevant spot, with a 50 mm (2 inch) plinth, an 800 mm (31½ inch) cabinet body, and a 28 mm (1 inch) countertop, you would reach about 880 mm (35 inches). Building a plinth from square timber is basically not that difficult, but depending on the floor, precisely leveling unevenness can be tedious.
If the overall planning allows, I would lower the work surface in front of the window by 10 or 20 cm (4 or 8 inches). This can be practical, for example, when baking bread. Lowering it by 20 cm (8 inches) could easily be done with 600 mm (24 inch) high cabinets, while a 10 cm (4 inch) lowering would require shortening the cabinet body.
