ᐅ IKEA Malm Nightstand Wobbles on Uneven Floor – Any Tips?
Created on: 20 Feb 2022 18:03
amankin
Hello everyone, I have an IKEA Malm bedside table at home – a very simple model with four legs. I noticed that this bedside table wobbles quite a bit on my uneven wooden floor and makes a slight rattling noise when touched or when placing something on it. I checked the floor, and in some areas, it’s slightly slanted, which seems to be causing the issue. What options are there to fix this wobbling without having to modify the bedside table or fully level the floor? Are there practical and sustainable tips I can try to make the bedside table more stable? Thank you in advance for your help!
PEDRO40
21 Feb 2022 14:19
I completely understand that a wobbly bedside table can be annoying. Especially on uneven floors, a table that is usually stable can become a real nuisance. 🙂 Maybe this is also a good opportunity to use the bedside table more creatively? For example, the cork or felt pads you put underneath could be combined with a nice rug or integrated as part of the room’s design. Sometimes it helps to combine a practical solution with a small visual highlight. How does the bedside table feel otherwise – is it easy to move, or rather heavy?
amankin
22 Feb 2022 08:54
Thank you all for the detailed tips!
jaanda schrieb:
Self-adhesive felt pads or small cork discs are practical solutions
That sounds like the best option to me since I don’t want to modify the furniture legs or rebuild the nightstand.
kemads46 schrieb:
Cut cork sheet to size and secure it with double-sided tape
I think I’ll try that and buy some cork specifically for this. Thanks also for the clear step-by-step instructions, they make getting started easier.
One more thing I’m curious about: Does anyone have experience with how durable these cork solutions are? Do they need to be replaced after some time, or do they really last for years?
rimole
22 Feb 2022 09:20
Cork lasts many years if it is properly installed. With high moisture levels or heavy use, it can wear out. Simply check it regularly. Do not cut it too thin.
Cecilera66
22 Feb 2022 09:45
I use self-adhesive felt pads on several pieces of furniture, even on uneven floors. They hold very well if the surface is clean and the pad is large enough. They help reduce wobbling, as long as the difference isn’t too big. For more stability, cork discs are more durable.
