ᐅ IKEA Malm Nightstand Wobbles on Uneven Floor – Any Tips?
Created on: 20 Feb 2022 18:03
amankin
amankin
20 Feb 2022 18:03
Hello everyone, I have an IKEA Malm bedside table at home – a very simple model with four legs. I noticed that this bedside table wobbles quite a bit on my uneven wooden floor and makes a slight rattling noise when touched or when placing something on it. I checked the floor, and in some areas, it’s slightly slanted, which seems to be causing the issue. What options are there to fix this wobbling without having to modify the bedside table or fully level the floor? Are there practical and sustainable tips I can try to make the bedside table more stable? Thank you in advance for your help!
meGreg
20 Feb 2022 19:26
Hey, I know this all too well – furniture on slightly uneven floors wobbles faster than you might expect 🙂 To fix this, you can, for example, stick felt pads or small self-adhesive furniture pads under the legs, which help to compensate for some unevenness. Alternatively, small wooden shims or pieces of felt that you cut to size also work well. Another idea is to place a single flexible cork pad underneath – this makes your bedside table more stable and less slippery without needing any major adjustments. And the best part: it also protects your floor!
jaanda
20 Feb 2022 20:17
To prevent wobbling of furniture on uneven floors, there are several established methods: 1. Adjustable furniture glides: These replace the standard feet and allow precise height adjustment. 2. Using suitable wedges or plastic discs to compensate for irregularities. 3. Applying anti-slip materials that also provide stability. Since the Malm bedside table does not have adjustable feet, self-adhesive felt pads or small cork discs would be a practical solution that can be implemented without tools. Leveling the entire floor is labor-intensive and often unnecessary if individual adjustment points can help.
amankin
21 Feb 2022 07:48
Thanks in advance for the answers! @meGreg, I find the idea of cork interesting. So you can simply cut the cork material and place it under the table legs that are too short? Or does it hold up well over time and not slip easily? @jaanda: Do you think self-adhesive felt pads are sturdy enough to prevent wobbling, or are they more intended for floor protection? I’d prefer a solution that doesn’t require frequent adjustments.
O
olivernu
21 Feb 2022 09:32
Felt pads are primarily effective for protecting floors and preventing scratches. They can also help stabilize furniture if the unevenness is not too great and the pads are thick enough. Cork, on the other hand, is a firmer material and stays in place when properly secured (e.g., with adhesive or double-sided tape). I recommend measuring the difference in height between the shorter leg and the floor precisely, then cutting a cork sheet to the appropriate thickness and securing it well. This provides lasting stability. Alternatively, adjustable feet are available, which can also be purchased as replacements for IKEA furniture.
kemads46
21 Feb 2022 10:45
Here is a short guide in case you decide to use a cork sheet: 1. Measure the height difference between the wobbly leg and the others using a ruler or tape measure. 2. Get a cork sheet with the right thickness or several thinner pieces you can stack. 3. Cut a piece of cork that fits exactly under the wobbly leg. 4. Attach it firmly with strong double-sided tape or wood glue – double-sided foam tape also works well. 5. Check if the nightstand is now stable. If not, adjust the cork thickness. Advantages of this method: low material costs, easy to implement, improved stability, and no permanent alteration to the furniture.
