ᐅ IKEA Malm Nightstand Finish Peeling – How to Repair It?
Created on: 29 Nov 2024 08:03
tedige
I have a problem with my IKEA Malm bedside table where the color or surface is starting to peel off at some edges. Specifically, it’s the matte finish on the sides that peels or has small spots where the surface seems to chip off, especially in high-wear areas like the edges.
I’d like to repair this as neatly as possible, and I would appreciate any tips on how to do this so that the repair is not very noticeable and the surface isn’t damaged further. Are there any proven methods or materials suitable for this type of repair?
I’m very grateful for any advice, maybe someone has successfully fixed something like this before.
tedige
30 Nov 2024 08:13
Nabla64 schrieb:
If you decide on a paint, I recommend spray paints for furniture that are specially designed to adhere to films.
Hello, I read your detailed advice yesterday and wanted to ask again: When using spray paint, which type of paint and finish do you recommend based on your experience for the matte film on the Malm nightstand?
I want to avoid repair spots standing out with a glossy shine, as that would look quite unattractive. Are there specific products that adhere well to plastic films and dry with a matte finish?
Thanks in advance!
Nabla64
30 Nov 2024 08:52
tedige schrieb:
For the matte finish on the Malm table’s foil, I recommend using matte spray paints based on acrylic lacquer, as they adhere well and do not gloss.
In addition to the matte layer, make sure the spray paint is specifically suitable for plastic. Brands like "Krylon Fusion All-In-One" or "Rust-Oleum Painter’s Touch" work very well.
Always apply the paint in thin layers and allow each layer to dry thoroughly. This minimizes dripping and runs, which is especially important for repair areas. Before spraying, test briefly on the inside of an inconspicuous spot to ensure the foil does not come loose.
I also recommend lightly sanding the repaired area before spraying (e.g., with 600-grit wet sandpaper) to improve adhesion.
Domau0
30 Nov 2024 10:30
tedige schrieb:
Are there any specific recommendations for coatings that adhere well to plastic films and dry with a matte finish?
If you want to be on the safe side, use a 2K acrylic clear coat in a matte finish, but you need to work very carefully and ensure good ventilation.
Alternatively, so-called primers or adhesion promoters based on polyvinyl chloride (PVC) are ideal and should be applied before painting. This is especially important if the film is old, as it improves the paint’s adhesion.
A small note: repairing films is always somewhat delicate because they are flexible. Too rigid paint films can easily crack due to temperature changes or movement.
