ᐅ IKEA Malm Nightstand Finish Peeling – How to Repair It?
Created on: 29 Nov 2024 08:03
tedige
I have a problem with my IKEA Malm bedside table where the color or surface is starting to peel off at some edges. Specifically, it’s the matte finish on the sides that peels or has small spots where the surface seems to chip off, especially in high-wear areas like the edges.
I’d like to repair this as neatly as possible, and I would appreciate any tips on how to do this so that the repair is not very noticeable and the surface isn’t damaged further. Are there any proven methods or materials suitable for this type of repair?
I’m very grateful for any advice, maybe someone has successfully fixed something like this before.
Domau0
29 Nov 2024 12:47
Hello tedige,
I’ll go into some detail because the topic involves a few pitfalls due to the laminate or foil coating.
First, you should definitely check whether only the surface is damaged or if the underlying board (MDF or particleboard) has already absorbed moisture or been damaged. This significantly affects the approach.
Let’s assume it’s just the foil:
- Step 1: Clean the chipped areas and lightly sand them with 400-grit wet sandpaper to create a new adhesion surface.
- Step 2: For smaller damages, furniture repair pens are suitable, but the color must match exactly. This is especially important for matte foils because gloss levels are critical.
- Step 3: For larger areas, you can use color pens or water-based acrylic paints. Pay special attention to primer adhesion; it’s recommended to use a foil primer beforehand.
- Step 4: Finally, apply a very thin, matte clear coat (water-based, applied in several thin layers) to avoid color differences and wear.
Also important: work in warm, dry rooms and allow sufficient drying time.
Question: How large are the damaged areas in your case? Smaller than 1 cm (0.4 inches) or several centimeters? This influences the optimal procedure.
I can then provide further product recommendations.
tedige
29 Nov 2024 13:05
Domau0 schrieb:
Question: How large are the affected areas for you? Smaller than 1 cm (0.4 inches) or several centimeters?
Thanks for asking! Mostly, these are small detached pieces of the film at the edges, around 0.5 to just under 1 cm (0.2 to 0.4 inches), but in some spots, the film is slightly torn, causing small edges to lift. I don’t have any actual "holes" in the surface yet.
I’m mainly looking for a quick and clean repair for the typical stress zones along the edges, without having to re-cover the entire table.
Palenar
29 Nov 2024 13:59
Hello tedige,
Based on your description, it’s a typical case of slightly damaged film coating in mechanically stressed areas – especially common with Malm nightstands.
For repair, I recommend the following workflow:
1. Protect the surrounding area and work in a dust-free, well-ventilated space.
2. Carefully trim loose film edges straight with a small cutter, then wipe the area with isopropanol.
3. Small holes and peeled-off spots can be filled with a tough, color-matched repair wax. After applying, smooth it with an iron to create a mostly level surface.
4. For cracks, a thin, flexible synthetic resin lacquer (e.g. water-based acrylic) is recommended. It dries matte and seals the film.
5. Edges are especially challenging because the film tends to detach more easily there, due to usually lower adhesion. To reinforce, thin edge banding strips can be cut to size and fixed with special contact adhesive.
6. Important: Wait at least 24 hours before doing any fingertip tests to ensure proper curing.
If you want, I can provide some product recommendations, including compatible colors and lacquers.
By the way, how often is your nightstand moved or subjected to heavy use? This can affect the repair’s durability.
tedige
29 Nov 2024 14:28
Palenar schrieb:
How often is your bedside table actually moved or subjected to heavy use?
It basically stays fixed in its place but is occasionally touched or leaned against at the edges during the day, for example when getting out of bed. More intense movements or stresses like bumping or sliding are less frequent. So the usage is normal, with no exceptional strain.
Thanks also for the very detailed explanation! Yes, product recommendations would be very helpful.
juMira46
29 Nov 2024 14:54
Hi everyone!
I find the discussion here really interesting and wanted to add a little tip:
If the scratches aren’t too deep, I’ve had good results using a slightly thicker layer of a fabric marker, which I then gently polish with a soft cloth. This helps to even out small imperfections, and afterwards, they’re hardly visible!
The key is: don’t apply too much at once and let it dry a bit in between. I like to use a small sponge instead of applying directly with the marker. This allows for a very fine application.
Good luck with the repairs – by the way, it’s actually quite enjoyable once you get the hang of it!
Elijah42
29 Nov 2024 15:16
One last tip: If the edges of the membranes are frayed, use a utility knife to cut the edge cleanly; otherwise, it will continue to tear.
