ᐅ Protecting IKEA Malm Furniture During Transport – Packaging Tips?
Created on: 20 Dec 2020 14:37
luaugust
luaugust
20 Dec 2020 14:37
I am planning to transport my IKEA Malm furniture soon and want to protect it as well as possible from scratches, dents, and other transport damage. The surfaces of the Malm dressers are quite delicate. Does anyone have experience or tips on the best way to package or protect this furniture during transport? For furniture like this, original boxes or padding are rarely included. What materials are suitable for packaging, how should they be secured, and what should be especially considered to avoid damage?
Thanks in advance for any helpful ideas and suggestions!
LOJOPAR
20 Dec 2020 16:42
Hello luaugust,
I think your question about protecting IKEA Malm furniture during transport is very relevant, as this topic is often underestimated. Here is a simple step-by-step guide based on how I do it:
1. Disassemble as much as possible: Removing the drawers reduces weight and prevents them from rattling or opening during the trip.
2. Protect surfaces: The surfaces of Malm furniture are usually painted and sensitive to scratches. Bubble wrap works best here and should be placed completely over the surfaces. If you don’t have bubble wrap, blankets or old towels can be a temporary solution, though bubble wrap offers better protection against moisture and dirt.
3. Secure firmly: To keep the bubble wrap or blankets in place, use stretch film or wide adhesive tape (avoid sticking tape directly on the furniture to prevent residue – better to apply it over the wrap).
4. Protect corners: Corners and edges are especially vulnerable to damage. Foam protectors (even inexpensive corner pads from a hardware store) are ideal for cushioning impacts.
5. Positioning during transport: Make sure the furniture is transported upright to evenly distribute weight and avoid stacking other items on top.
In summary: Disassemble, protect surfaces with bubble wrap, cushion corners, secure everything firmly, and load carefully.
Hope this helps! If you want more details, feel free to ask.
GAGRAHAM
20 Dec 2020 19:05
Oh wow, I really love topics like this! 🙂
LOJOPAR schrieb:
Bubble wrap is best, you should cover all surfaces completely with it.
That’s brilliant! Bubble wrap really provides excellent protection, I’ve done the same myself! And protecting the corners with foam – perfect!!!
You also shouldn’t forget to secure all parts well, so nothing shifts or rubs. I once used thick blankets during a move and then wrapped everything tightly with stretch film, which worked really well and all the furniture arrived safely!
So use bubble wrap, foam, and wrap everything tightly together with stretch film, then it will definitely work great!
Good luck with the transport, it’s sure to go fantastic! 🙂
Genevieve
21 Dec 2020 09:18
I would like to briefly point out that it’s worth carefully considering whether bubble wrap and foam padding alone are always the best solution, depending on the type of transport.
GAGRAHAM schrieb:
And also protecting the corners with foam – perfect!!!
Of course, foam protects the corners, but it’s important to know how the transport will be carried out – for example, during longer trips on uneven roads, furniture can still collide despite padding.
One aspect that many overlook is choosing the right packaging size and securing the position as firmly as possible inside the vehicle. Just because the corners are padded doesn’t mean the furniture is fully protected against deformation.
My advice: In addition to padding, use anchor points in the vehicle or plan for tie-down straps to keep the furniture in place. A wide fixation helps prevent tipping over.
Does anyone have experience with these anchor points specifically for home storage or rental trucks?
REOHEINRIC
21 Dec 2020 12:47
Regarding the discussion around transporting IKEA Malm furniture, I would like to add some precise points:
1. Surface and edge protection: Bubble wrap is standard, but I recommend adding furniture blankets made of felt or fleece for better scratch protection. These are more durable and prevent abrasion.
2. Avoid direct contact of adhesive tape: Tape should not be applied directly to surfaces, as removing sticky residue later often requires solvents that can damage the material.
3. Corners: Special edge protectors made of foam or cardboard are useful here, such as affordable "edge guards."
4. Storage in the transport vehicle: Furniture should always be transported upright to distribute the load evenly across the particle boards and minimize deformation.
5. Securing: Use ratchet straps or tie-down straps attached to sturdy points in the vehicle to prevent shifting or tipping.
6. Moisture protection: Avoid placing furniture directly on wet surfaces, as the material can swell.
I recommend documenting everything with photos of the packaging methods before transport to have better grounds for claims in case of damage.
This way, transport can be secured almost professionally.
