ᐅ IKEA Malm dresser wobbles during use – how can I stabilize it?
Created on: 27 Jul 2024 18:42
elian64
elian64
27 Jul 2024 18:42
Hello everyone, I have an IKEA Malm chest of drawers at home that starts to wobble during normal use as soon as one or more drawers are pulled out and you lean on or slightly move the chest. The wobbling is noticeable and not only looks unsteady but also feels insecure. I have already checked whether all screws are tightly fastened – according to my inspection, they are.
My question is: What specific measures can I take to permanently reduce or completely stop the wobbling of the Malm chest of drawers? Are there known weak points in the assembly of this chest that should be reinforced? Would it be advisable to apply additional pressure in certain areas or use special aids (e.g., small wedges, mounting brackets, cushioning materials)?
It would be great if you could briefly share whether you are familiar with this problem and how you solved it in your case. Thanks in advance!
klo61
27 Jul 2024 19:07
Hello elian64, wobbling is unfortunately a common issue with the Malm dresser, often caused by various factors.
First: Check if all screws are properly tightened, including the hidden ones inside the drawer runners and at the back panel. Sometimes screws may seem tight but are not correctly seated in the wood connector.
elian64 schrieb:
I have already checked if all screws are properly tightened – according to my inspection, they are.
Another important point is the adjustable leveling feet: The Malm dresser has small screws to adjust its height. Make sure they all touch the floor evenly and that the dresser is level. An uneven floor can increase wobbling.
It also often helps to secure or fasten the dresser to the wall to prevent sideways tipping. IKEA usually provides brackets for this purpose. If you haven’t done so yet, definitely install them.
Another idea is to use small non-slip rubber pads or self-adhesive felt gliders under the feet – these often improve stability, especially on smooth floors.
If you like, please describe the floor surface in more detail and whether you have already secured the dresser to the wall.
RENMA
27 Jul 2024 20:53
In brief and factual terms: The wobbling of the IKEA Malm chest of drawers typically occurs due to missing wall attachment and uneven load distribution when drawers are pulled out.
klo61 schrieb:
Another idea is to place small non-slip rubber pads or self-adhesive felt pads under the feet
This can help temporarily but is not a substitute for proper assembly, especially securing the back panel and attaching the unit to the wall.
Recommendation:
1. Check all fasteners and tighten if necessary.
2. Attach the chest of drawers to the wall using the supplied bracket.
3. Check the floor level and use shims if needed.
4. Verify correct drawer installation (clean guides, not warped).
I would also like to point out another common issue: looseness of the back panel. When fitted tightly, it stabilizes the unit against lateral wobbling caused by drawer use.
Once all these points have been checked, the chest of drawers should be stable.
Marcellela
28 Jul 2024 08:31
Stop Wobbling:
- Secure the dresser firmly to the wall (use brackets)
- Check and adjust the leveling feet
- Mount the back panel tightly
- Check all connection screws
This is usually sufficient.
Domau0
28 Jul 2024 14:17
I would like to explain in more detail the technical reasons why the Malm dresser tends to wobble during use and how to address this problem most effectively.
First, it is important to understand that the dresser is typically designed as a lightweight cabinet with moderate stability. The drawers carry loads and can easily push the frame sideways when under stress, which causes the wobbling.
I recommend the following steps to secure it:
1. Make sure all screws and connectors, especially cam locks and dowels, are tightened properly using the appropriate screwdriver. Often, these are only hand-tightened, but they should be fixed with noticeable resistance.
2. The back panel acts as a crucial diagonal brace. Check whether it sits flush without gaps against the cabinet frame. A back panel that is not fully engaged or slightly damaged greatly reduces stability. If it feels too flexible, a thin plywood board can be screwed on from the inside as reinforcement.
3. The adjustable feet under the dresser usually can be fine-tuned. Using a spirit level, align the entire piece of furniture precisely. Even slight unevenness on the floor can cause rocking and wobbling.
4. Securing the dresser to the wall is the step that ultimately minimizes wobbling. A simple metal bracket with screws is sufficient, provided the wall is sturdy. For drywall (plasterboard) walls, appropriate anchors should be used to ensure a secure hold.
5. As an additional tip, small wedges or rubber pads under the feet can help if the floor is very smooth or uneven. These absorb minor movements effectively.
My advice: systematically check these points and reinforce the back panel if necessary. Without a back panel, the dresser is almost always unstable.
