ᐅ IKEA MALM dresser suddenly squeaks – troubleshooting possible causes?
Created on: 11 Nov 2024 08:37
jacques3Hello everyone,
Over the past few days, I've noticed that my IKEA Malm chest of drawers—specifically the model with four drawers and a black wood finish—has started to squeak quietly but noticeably when opening and closing. Since I have been using the chest for about two years now, I don't assume it is suddenly defective. I have already checked for loose screws and whether the drawer slides have dirt, but I couldn't find anything unusual.
My question is: What are common causes of unexpected squeaking in a Malm chest of drawers? Are there known sensitive spots to check specifically, or any household remedies to eliminate the noise? I’ve read that some users lubricate the drawer slides, but I’m hesitant to do anything that might cause damage. I’m happy to receive any well-informed tips or shared experiences!
Hello jacques3,
to effectively eliminate the squeaking in your MALM dresser, I recommend a step-by-step approach:
1. Remove the drawers and thoroughly check the sliding rails for dirt, dust, or small wood splinters.
2. Then lightly treat the metal rails with silicone spray or white graphite powder – both are silicone-based and do not leave an oily residue.
3. Check the screws at key connection points, as wood and metal can shift due to temperature changes.
Common mistakes include:
- Using no lubricant or the wrong one (avoid WD-40 or oil!).
- Not tightening screws, which can cause friction between wooden parts.
If you can provide more details about when the squeaking occurs (when closing or opening?), feel free to share here.
Good luck!
Good luck!
Hello Jacques,
I like to take a closer look at this typical squeaking issue with a MALM dresser. Your description that the squeaking appeared suddenly and unexpectedly suggests that it is caused by friction resulting from abrasion or slight shifts in the structure.
The primary causes are usually:
- Cross-grain wood joints: These are often glued, but fluctuations in moisture cause the wood to expand or shrink, creating small tensions. These lead to friction noises, especially under load (i.e., opening and closing).
- Sliding rails and guides: The MALM typically has metal rollers or plastic gliders. Dust or tiny particles in the guide rails can cause squeaking, especially if there is no lubrication.
- Screws or fasteners: Loose screws can make the structure slightly unstable, increasing friction. Sometimes a slight retightening helps—but be careful, as overtightening can cause stress.
I recommend:
1. Check whether the wood parts (especially at edges and joints) are dry or possibly a bit dried out.
2. Possibly apply a light coat of wood maintenance oil that does not change the surface but reduces friction.
3. For the sliding rails: as mentioned, use silicone spray sparingly to avoid attracting dust.
Have you tried to precisely locate where the squeaking comes from? With a mechanical test (quietly opening and closing) or if multiple drawers are affected, you can better narrow down the cause. Please let me know whether the noise occurs in all drawers or just one, as this helps a lot.
One more question: Is the dresser placed on a very hard or rather soft floor? Sometimes noises are transmitted through vibrations that the floor amplifies.
Looking forward to more details!
I recommend:
warrenka5713 Nov 2024 20:04jacques3 schrieb:
My question is: What are the common causes of unexpected squeaking in a MALM chest of drawers?I can relate to that; those small, unexpected noises can be quite annoying. I had the same issue with my MALM a few months ago – in my case, it was a combination of dry drawer runners and a slightly loose part on the back panel.
A tip from my experience: approach it step by step and don’t get discouraged if the first attempt doesn’t fix it right away. Sometimes it just takes a bit of patience. What also helped me was a careful check to see if the chest was wobbling anywhere or if it wasn’t standing completely flat.
I hope you find a solution, good luck with it! 🙂
