I have noticed clear signs of rust on some screws of my IKEA Malm dresser, which surprised me since I bought it a little over two years ago and have used it normally. The rust mainly forms around the screw heads and partially on the nut-like connectors inside. I suspect this could be due to a material issue or possibly a result of moisture or poor ventilation.
My question is: How can I specifically prevent the rust from spreading further without completely dismantling or replacing the dresser? Are there proven methods for rust protection on such furniture connections that can be done at home with limited effort? Also, does anyone have experience whether IKEA offers goodwill in such cases or possibly provides replacement parts?
I appreciate any advice, especially practical tips that go beyond theory.
haure42 schrieb:
some screws show clear signs of rustRust on screws in furniture like the IKEA Malm chest of drawers is often an indication of non-stainless material or moisture-related oxidation. To stop it from progressing, I recommend the following steps:
1. Carefully loosen and fully remove the screws, if possible.
2. Remove rust using sandpaper or a wire brush.
3. Then treat the screws with rust-inhibiting oil or a thin layer of corrosion protection.
4. Alternatively, obtain replacement screws made of stainless steel, which are much more resistant to rust.
Since IKEA generally offers only limited goodwill for such wear, it is advisable to contact customer service. Often, replacement parts can be ordered, but this usually requires documented defects.
It is also important to check the source of moisture and possibly improve air circulation around the furniture’s location.
KAULIS schrieb:
Alternatively: get replacement stainless steel screws, which are significantly longer-lasting against rustThat is a very good tip. I would like to add that when removing rust and applying protection, it is important not to treat the screws too aggressively to avoid damaging the threads.
I also recommend wiping and drying all areas around the screws before treatment to remove any remaining moisture.
If you use replacement stainless steel screws, make sure to check the correct dimensions and strength grade (e.g., A2-70), comparable to the IKEA screws. This will help prevent issues during assembly.
If you are still very unsure: there are special clear coats for metal that can be applied after rust removal to protect the material over the long term.
flo-Theres2 Sep 2024 11:34haure42 schrieb:
whether IKEA itself shows goodwill in such cases or possibly offers replacement partsI have had similar experience with a Malm chest of drawers. IKEA does indeed offer replacement screws if you provide proof of purchase—ideally with a receipt and photos. Repair kits are rare, and this usually concerns individual screws. The customer service hotline is patient, but you need to be polite and firm.
In practice, applying a thin layer of wax (e.g., furniture wax) around the screws after installation helped me create a barrier against moisture. With stainless steel screws, I didn’t need to do this at all.
