ᐅ IKEA Malm drawers come out when pulled – how to secure them?
Created on: 22 Jul 2020 19:23
keodo
keodo
22 Jul 2020 19:23
I have a problem with the drawers of my IKEA Malm dressers: when I pull them out, they often come completely off and no longer sit properly in the drawer slides. I suspect that the mechanism or the drawer attachment is not optimal or has become loose. My question is: what is the easiest and most secure way to fix the drawers in the Malm series so that they don’t fall out when pulled? Are there any special tricks or replacement parts that can permanently solve this issue? I have already cleaned and lubricated the slides, but unfortunately, that hasn’t helped enough.
Thank you in advance for your tips!
LEEJU
22 Jul 2020 19:47
In the Malm series, the drawers are normally secured with side clips. Check if the clips are still intact or if they might be broken. If so, you can buy replacement clips individually from IKEA and easily swap them out. Otherwise, make sure they snap in properly and avoid pulling with too much force.
FAZAR
23 Jul 2020 07:14
Hello keodo,
I am very familiar with this issue; unfortunately, Malm drawers tend to come loose if the slides or locking clips are no longer properly aligned.
Basically, you should first check whether the drawer slides (that is, the rollers or metal runners on the side/in the dresser) are correctly aligned and undamaged. In the Malm series, the drawers have clip-like locks that snap into place at the rear end of the drawer – these often become loose or break after extended use, which can cause the problem you described.
My advice:
1. Test each slide individually to see if it moves smoothly and is not bent.
2. Inspect the plastic clips or hooks on the back of the drawer that secure it in the slide.
3. If possible, remove the drawer and reposition the clips; sometimes gently bending them slightly helps them grip better.
4. If any part is damaged, you can order replacements from IKEA – the item numbers can be found on their website.
A small note: This problem occurs more frequently with heavily loaded drawers, so the weight of the drawer might also be a factor. I would also take a look at how much weight is on it.
Can you also say whether the drawer falls out completely or only partially slips out? And how old is the dresser approximately? Then I could tailor the advice more precisely.
noge58
23 Jul 2020 16:09
FAZAR schrieb:
This problem occurs more often with heavily loaded drawers
Exactly! With my Malm drawers, I noticed that the less stuff inside, the less often a drawer completely comes out 🙂 But joking aside, I carefully filed down the clips a bit and now they hold really tight! I think it’s great that there are so many helpful tips here – don’t lose heart, you can manage this! 🙂
jelite
24 Jul 2020 10:35
Hello keodo,
I would like to add a structured approach that can help you securely attach the Malm drawers:
1. Accessory Check: Malm drawers usually have two plastic clips on the underside at the back that latch into the side drawer runners. If these clips are bent or broken, the fixation will no longer be secure.
2. Removal: Pull the drawer out completely. Inspect the clips carefully and check the drawer runners inside the dresser for any damage or bent metal parts.
3. Cleaning & Adjustment: Dirt or debris in the runners can prevent correct seating. Clean all runners with a fine cloth, ensuring there are no greasy residues.
4. Repair: If the plastic clips have loosened, you can gently bend them back to improve their engagement. Be careful not to apply too much force, as they can break! Replacement parts are relatively inexpensive and available from IKEA.
5. Weight Check: As FAZAR already mentioned, heavily loaded drawers can overload the clips. Ideally, weight should be distributed evenly and the drawer should not be overloaded.
6. Reinstallation with Pressure: When reinstalling, place the drawer straight onto the runners first, then push it back until the clips audibly snap into place.
If you follow these steps, the drawers should sit securely when pulled out. If they still stick or fall out, check whether the runners are bent, as that would be a more serious repair case.
If you like, I can also provide the corresponding IKEA replacement part numbers. Good luck!
