ᐅ IKEA MALM bed squeaks when moving – how to make it quieter?
Created on: 20 Jan 2021 07:23
JENNIFERSA
Hello everyone, I have had the IKEA Malm bed for some time now, and I’ve noticed that it squeaks quite a bit when moving. Especially when I turn over or get up at night, I hear this annoying noise. I have already tried checking the screws, but that didn’t help much. Are there any tricks or specific products to make the bed quieter? I would appreciate concrete tips on how to find the squeaky spots and eliminate them as permanently as possible. Thanks in advance!
JENNIFERSA21 Jan 2021 18:22Thanks in advance for the many tips! I will try using wax and felt at the contact points. I find the suggestion about
Is there a difference between liquid lubricants and dry ones like graphite powder, as
And what is the best way to keep the screws tight and free of creaking over the long term? Thanks in advance for your evaluation!
Timofa schrieb:interesting, but I take your warning seriously and will be careful.
silicone spray
jokau schrieb:? I want to keep the bed as low-maintenance and permanently quiet as possible without having to take everything apart again in a short time.
mentioned
Hello JENNIFERSA, regarding your question: Liquid lubricants like silicone spray penetrate well and are easy to apply, but they can attract dust and dirt, which may cause new problems over time. Dry lubricants such as graphite powder repel dirt and are ideal for screws and moving metal parts, although applying them sometimes requires a bit of experience. If you want to keep the bed stable in the long term, I recommend a combination: first, tighten the screws properly, possibly using some assembly adhesive or threadlocker if you want to be extra safe; then, apply felt or foam rubber at the wood-on-wood contact points and use graphite on the metal connections.
This also requires follow-up maintenance, especially during the first few weeks. For some beds, investing in better tools (e.g., a ratchet) for evenly tightening the screws is worthwhile. Good luck!
JENNIFERSA22 Jan 2021 07:39Thank you @Katau for the detailed explanation and your tips! This really helps me better understand how to work with the different materials. I will try using threadlocker and also add felt pads to the suspect areas. I’ll get back to you later with the results.
JENNIFERSA23 Jan 2021 09:48A quick update from me: Over the weekend, I tightened all the screws and applied felt strips to the wood contact surfaces. I also used graphite powder on the metal joints. The result is much better; the squeaking is almost gone!
Thanks again to everyone for the very helpful tips and for your patience with my questions. 🙂 It’s clear that many of you have gained a lot of hands-on experience here.
