kuehlwalda14 Mar 2016 19:56Hello!
I have the following question:
I installed a single-run Kvartal with the spacers mounted on the ceiling.
.... Set screws tightened. The rail is hanging .... but it can still be slid within the holders.
Did I miss something?
Thanks and best regards,
kuehlwalda
kuehlwalda
IKEA-Freund14 Mar 2016 20:58Hello,
first of all: I am not using Kvartal rails. If you have only pushed in the mushroom-shaped fittings for ceiling mounting, the rail should still be movable. You should achieve fixation through the screwed connecting pieces (even if you are installing just a single rail) – simply push them in completely.
Regards,
IKEA-Freund
Regards,
IKEA-Freund
kuehlwalda14 Mar 2016 21:22... you mean as a stopper in the track?
Then I would need two.
IKEA-Freund14 Mar 2016 21:43Hello,
the instructions suggest that two connectors are included. However, even if there is only one, it should be enough to secure the rail against lateral movement.
IKEA-Freund
IKEA-Freund
IKEA-Experte14 Mar 2016 22:09My KVARTAL can also be moved, but that has never been a problem. It does not move on its own.
kuehlwalda14 Mar 2016 22:44.... You would really need to install two; with just one, it could still be shifted to one side.
(yes, two are included)
.... but once again, not properly thought through by Ikea
