ᐅ IKEA KALLAX as an Aquarium Stand – Load Capacity?
Created on: 8 Jul 2022 18:37
lauel
lauel
8 Jul 2022 18:37
I’m considering using an IKEA KALLAX shelf as a base for my aquarium. The main question I have is: What is the actual weight limit of a KALLAX shelf when placing a water-filled aquarium on it?
Specifically, I’m interested in how many kilograms each individual compartment, as well as the entire shelf unit, can realistically support without compromising stability or damaging the material. My aquarium holds about 100 liters (26 gallons), and including the equipment and decorations, the total weight adds up to around 120-130 kg (265-287 lbs).
IKEA provides manufacturer specifications for load capacity, but these usually refer to books or typical household items, not a heavy, pressure-intensive aquarium.
I’m also wondering if it would be advisable to reinforce the shelf or stabilize it with special boards to better distribute the load.
I would appreciate it if anyone has experience using the KALLAX shelf as an aquarium stand or can offer advice on realistically assessing its weight capacity.
Thanks in advance for your input!
tutan
8 Jul 2022 19:12
lauel schrieb:
What is the actual load capacity of a KALLAX shelf if I want to place a water-filled aquarium on it?
Hey, interesting question! The KALLAX is basically designed to hold books and light decorative items, but it can support an aquarium if you take a few precautions.
The weight of about 120–130 kg (265–287 lbs) that you mentioned is significant, but not impossible for the shelf. The key is to distribute the weight evenly. Placing the aquarium directly on the glass surface of the shelf can cause point loads that might damage it.
My advice: place a plywood sheet or a similarly strong, flat board between the aquarium and the KALLAX. This will help spread the weight evenly across the compartments, allowing the shelf to support it better.
Also, make sure the KALLAX is standing level and stable. Unevenness can create stress, especially under such heavy load.
And keep in mind, the material isn’t solid wood, so it won’t remain stable forever under heavy weight. But with some care and reinforcement, you should be fine—I’d recommend keeping the total load under 150 kg (330 lbs) to be safe.
Good luck and happy aquascaping! 🙂
gasidney
9 Jul 2022 07:34
lauel schrieb:
What is the maximum load capacity of a KALLAX shelf if I want to place a water-filled aquarium on it?
According to the manufacturer, a KALLAX shelf can hold up to 13 kg (29 lbs) per compartment. Therefore, it is not suitable for aquariums without reinforcement.
tutan
9 Jul 2022 08:46
gasidney schrieb:
According to the manufacturer, KALLAX supports a maximum of 13 kg (29 lbs) per compartment.
Yes, the official specifications are based on typical household loads. However, you can significantly increase the strength of the shelving unit by adding continuous reinforcement.
lauel schrieb:
whether it would be advisable to reinforce the shelf additionally or stabilize it with special panels
Exactly, you should definitely do that. A plywood or MDF panel increases the load capacity because it distributes the weight across multiple connection points instead of concentrating it on individual compartments.
Reinforcing the back panel with sturdy boards also adds stability. Such a creative upgrade of the KALLAX is quite common in aquarium setups.
For comfort and safety, I would definitely pay attention to the total weight—better to have a little less than too much. 🙂
