ᐅ IKEA FAKTUM Horizontal Wall Cabinet – Door Does Not Stay Open at the Top
Created on: 10 Feb 2014 09:13
Tammy_5417
Tammy_5417
10 Feb 2014 09:13
I have a small installation issue with the horizontal wall cabinet of the Faktum kitchen.
Unfortunately, the door does not stay open at the top when I open it. I can’t make sense of the assembly instructions.
Where the screwdriver is supposed to be inserted to adjust the weight of the door (so that it stays open at the top), there is no screw to adjust.
Is that correct? Or is the adjustment made somewhere else?
I would be very grateful for any help 🙂
IKEA-Experte
10 Feb 2014 10:38
There must be a screw. Something inside, not on the surface. In some cases, it needs to be turned a lot. It’s best to use a cordless drill.
Tammy_5417
10 Feb 2014 14:16
Great, thanks for the video. It looks like this screw is actually missing in my case.
IKEA-Experte
10 Feb 2014 14:46
If I remember correctly, it’s more of a conical pinion than a regular screw head that is driven by a Phillips screwdriver. Maybe Nordkäppchen can give a more detailed description of how it looks inside the hole.
Tammy_5417
11 Feb 2014 08:08
Thanks for the tip that it’s actually not a real screw you can see right away. I just held the cordless drill to it, and it worked 🙂
Machiste
2 Mar 2014 12:43
Many thanks to the Ikea expert!
I was also struggling with the Ikea instructions. The problem is that once the door is attached, you can’t see where to insert the screwdriver or what size to use. Only when I used a power drill did it immediately work. Great to have the links to the video tutorials. Excellent, I’m impressed.
Best regards from Hamburg
Machiste
