ᐅ Ikea Billy Bookshelf – Quality, Assembly, and Load Capacity
Created on: 28 May 2025 16:15
seidenmattS
seidenmatt28 May 2025 16:15Hello everyone,
I’ve been considering getting a Billy bookcase from IKEA for a while now because I simply need more space for my books. However, I’m wondering how sturdy the bookcase really is, especially if you want to store many heavy books. Can the Billy handle that, or would it be better to choose a different shelf? Also, how easy is it to assemble – can you manage on your own without any problems, or is it much easier with two people? And what about buying additional shelves later on?
I’d really appreciate hearing about your experiences!
Aloha_Lars28 May 2025 16:34Hello,
the construction is simple. I have two Billy units in my office. They are fine for books. I have one shelf with heavy lever arch files, and the shelf has started to bend slightly. However, this is only noticeable upon close inspection. Everything is perfect for the books.
Good luck Aloha
Good luck Aloha
Schnackischnak1 Jun 2025 18:54Hello,
Your questions about the Billy bookshelf touch on the very issues that make this piece either iconic or a constant topic of debate. Basically, the Billy is designed to easily handle typical amounts of paperbacks, standard literature, and other household items. However, if your books tend to be large heavy volumes, encyclopedias, or coffee-table books, caution is advised. The shelves can sag under continuous heavy load, especially if they are not perfectly placed or if the small pins are not properly fitted everywhere. Some users replace the boards after a while or add additional supports because of this.
Replacement shelves are usually available as long as the series is still produced in the chosen color or finish—this is not a firm guarantee, especially with IKEA, but they often remain available for a surprisingly long time, either directly in stores or by special order. Those who want to be thorough often buy an extra set of shelves when purchasing. The exact shelf heights are limited by the pre-drilled hole rows.
If you think of Billy simply as a bookshelf rather than a heavy-duty storage unit, you’ll rarely be disappointed. With careful assembly and occasional checks on the shelves, it is an affordable solution offering plenty of space.
Schnackischnak
Schnackischnak
NeuerAlter2 Jun 2025 09:01Hello,
the Billy shelf is sturdy enough for most typical books – such as paperbacks, novels, and non-fiction books. However, with very heavy books or many thick binders, it reaches its limits, as the shelves may start to sag over time. It is especially important to assemble it carefully and secure the back panel well, as this provides most of the stability.
The assembly is straightforward. One person can manage it with patience, but two people make it easier, especially when standing it upright and aligning it properly. Additional shelves are usually easy to obtain as long as the shelf model and the matching color are still available. However, the shelf heights are fixed due to pre-drilled holes – there is no flexibility like with custom-made units.
As a shelf for a normal amount of books, Billy is a proven solution. For heavy reference books, atlases, or art books, it is advisable to either reduce the load, consider additional supports, or look for other furniture series. As long as these limits are respected, the shelf reliably serves its purpose.
wiltshire2 Jun 2025 09:27The Billy bookshelf has undergone several changes over its history, including those affecting its stability. I had no issues with the Billys from the early 2000s – they were very sturdy. The Billys my mother bought around 2021 felt noticeably "lighter" and less reliable. If I’m correctly informed, there was another structural change the year before last. Therefore, it makes sense to ask about experiences with units purchased after 2024.
Unfortunately, I cannot contribute any personal experience regarding the current models.
