ᐅ Ikea Besta – which protective finish is best for preventing scratches?
Created on: 2 Aug 2023 09:12
Jeremypin
I am considering applying a protective clear coat to my Ikea Besta shelving unit to prevent scratches. For those unfamiliar with it: the Besta series often has a practical but delicate painted surface that can easily develop small scratches from everyday use, especially on white or high-gloss finishes.
I am particularly interested in which protective clear coat would work best for this piece of furniture—both in terms of compatibility with the original finish and durability against scratches. It would also be great to know whether the clear coat remains visible after application (for example, glossy or matte) or if it protects without being noticeable. Do you have any recommendations regarding specific product types (acrylic, polyurethane, water-based, spray, etc.) or particular brands that work well on Besta surfaces?
Thank you for your tips and experiences!
Jeremypin
3 Aug 2023 08:11
CHENFAR schrieb:
Important: Always perform a compatibility test before use, as paints often adhere poorly to melamine-coated surfaces.
Thanks for the tip, I didn’t know that. This makes things a bit more complicated because I’m not sure if my Besta shelf is melamine-coated or painted.
Is there a simple way to find out without damaging the furniture? Something that allows me to reliably determine which surface finish was used?
And if it is melamine-coated, are there any practical protective paint options, or only films or other protective methods?
U
uslis47
3 Aug 2023 12:05
Hello Jeremypin,
your question is very important because correctly assessing the surface is the basis for an effective protective system.
Melamine coatings are usually very hard and smooth, which makes applying paint difficult and results in poor adhesion. A simple test: if the surface is very hard and scratch-resistant and feels like plastic, it could be melamine. If you gently scratch it with a fingernail and nothing happens, that indicates melamine.
Painted MDF or particleboard often have a smoother texture and are somewhat more sensitive to mechanical stress.
For melamine, I recommend:
- Using special adhesion promoters (primers) designed for melamine before painting.
- Followed by clear coats based on polyurethane (PU).
- Or, as Kautra already mentioned, use protective films or matte protective panels as coverings.
If you are unsure, test a small, hidden area with primer and paint. The durability will then provide an indication.
I hope this helps you.
Kinbu
4 Aug 2023 07:52
Jeremypin schrieb:
Is there a simple way to determine this without damaging the furniture?
One method I use myself is a combination of touch and visual inspection.
Melamine often has a very hard, almost plastic-like surface, while painted finishes tend to feel a bit more lively and “softer.”
I also like to apply small test spots with a little nail polish remover in an inconspicuous area, of course very carefully. Melamine doesn’t react as strongly to it as painted surfaces, which often soften slightly or become dull.
If you hesitate about the test, minimal samples are usually enough and can be easily cleaned off with a damp cloth.
After that, you can choose the appropriate paint or check for films if it turns out to be melamine.
Good luck with your project!
