ᐅ Ikea Besta – which protective finish is best for preventing scratches?
Created on: 2 Aug 2023 09:12
Jeremypin
Jeremypin
2 Aug 2023 09:12
I am considering applying a protective clear coat to my Ikea Besta shelving unit to prevent scratches. For those unfamiliar with it: the Besta series often has a practical but delicate painted surface that can easily develop small scratches from everyday use, especially on white or high-gloss finishes.
I am particularly interested in which protective clear coat would work best for this piece of furniture—both in terms of compatibility with the original finish and durability against scratches. It would also be great to know whether the clear coat remains visible after application (for example, glossy or matte) or if it protects without being noticeable. Do you have any recommendations regarding specific product types (acrylic, polyurethane, water-based, spray, etc.) or particular brands that work well on Besta surfaces?
Thank you for your tips and experiences!
Kinbu
2 Aug 2023 09:43
Hello Jeremypin,
that is a good and very valid question. Especially with furniture like Ikea Besta, which usually uses lacquered particleboard, you need to be careful because not all protective coatings react well with the surface.
I would recommend using a water-based acrylic varnish. It is generally very compatible with existing paint layers and does not yellow over time. It is also available in matte, satin, or glossy finishes, so you can choose the effect you want.
Regarding scratch resistance: No varnish makes the surface 100% scratch-proof, but thicker layers with good hardness significantly improve protection. Make sure that the varnish is marketed as "scratch-resistant" or "durable."
An alternative is polyurethane varnishes (PU varnishes), which are usually harder but can sometimes have a slight yellow tint or be a bit more difficult to apply.
If possible, test first on an inconspicuous spot. Important: Before varnishing, clean the surface well, lightly sand it (fine sandpaper), and keep it dust-free.
Hope this helps you further!
Timmyse36
2 Aug 2023 10:08
Kinbu schrieb:
No finish makes the surface 100% scratch-resistant, but thicker layers with good hardness significantly improve protection.
Unfortunately, you have to let go of the hope for complete scratch resistance early on—especially for furniture that gets a lot of daily use.
I once tried a water-based acrylic finish on my Besta—at first, I was quite satisfied, mainly because it became almost invisible and didn’t yellow. Still, over several months, fine micro-scratches appeared, but the surface does feel somewhat more durable.
My recommendation: if you want something for long-term use, regularly touch up or renew the finish. And don’t rely solely on the finish—consider using felt pads under objects or handling items carefully.
peovin
2 Aug 2023 11:15
PU varnishes are the best choice for Besta if you want to prevent scratches. Acrylic varnish provides protection but is softer.
Spray paints are not suitable because they can result in an uneven finish. Use a brush or roller.
Before painting, be sure to lightly sand the surface.
CHENFAR
2 Aug 2023 11:33
Additional information:
- Besta surfaces are usually made of melamine-coated particleboard or painted MDF panels, which affects the adhesion of protective coatings.
- Water-based polyurethane finishes with a matte or satin sheen are recommended. They offer good protection combined with high scratch resistance.
- Acrylic paint can be used but is less durable against mechanical wear.
- Important: Always conduct a compatibility test before application, as coatings often adhere poorly to melamine-coated surfaces.
- Applying multiple layers with sanding in between enhances the protective effect.
The visibility of the finish depends on the type – matte finishes provide a more natural look, while glossy ones are usually more noticeable.
A sealing coat with a polymer sealer after the finish might also be worthwhile.
kautra
2 Aug 2023 14:27
Caution with melamine surfaces: paint often adheres poorly and can peel off.
For Besta, I would recommend testing protection with film or clear lacquer sprays.
Acrylic water-based lacquer is good but not very durable.
