ᐅ Ikea Besta – What to do if assembly gets stuck halfway through?
Created on: 30 Nov 2024 19:42
Esraren
I am currently in the middle of assembling my Ikea Besta cabinet and have encountered a problem that I can’t resolve. The instructions are generally clear, but I’m unsure how to securely connect the side panels to the back panel. Specifically, in step 7, I am asked to insert and screw in the back panel, but the pre-drilled holes do not align perfectly. This makes it difficult to insert the screws straight, and I’m worried about damaging the material or not being able to set the cabinet up level afterward.
My questions are:
- Is it normal for the holes in Ikea Besta cabinets to sometimes not match perfectly, or could this indicate a manufacturing defect?
- Are there any tips or techniques to install the back panel as securely as possible without damaging the wood?
- Should I force the screws in anyway, or is it better to wait and maybe contact Ikea customer service first?
I only have standard tools available (screwdriver, cordless drill with torque control) and have some experience with furniture assembly, but this issue has me stuck. I would really appreciate any help or shared experiences!
neoren
2 Dec 2024 07:04
I would recommend:
- Align the back panel with the groove.
- If the holes do not match, pre-drill carefully.
- If too much force is required when screwing in, stop and reposition.
Otherwise, the wood can easily be damaged.
warrenka57
2 Dec 2024 18:31
That sounds really frustrating, especially after getting so far and then suddenly getting stuck. I had a similar experience with a shelf.
What helped me was to calm down, take a proper deep breath, and then start again with a bit of distance. You shouldn’t put yourself under too much pressure, or assembly will stop being enjoyable.
Maybe it will help if you first roughly assemble just the side panels and only carefully fit the back panel at the end. This way, you can still make adjustments before everything is firmly screwed together.
Keep us updated!
Davidleo
3 Dec 2024 08:39
warrenka57 schrieb:
What helped me was to calm down, take a deep breath, and then start again with some distance.
Very important! Especially when assembling furniture, sometimes the best remedy is to take a short break and refocus.
Esraren schrieb:
I only have standard tools available (screwdriver, cordless drill with torque limiter) and I’m quite experienced with furniture assembly, but this point is still causing me to stall.
Exactly your calm and structured approach will surely get you back on track quickly. You have a good plan and are well prepared – you got this! 😉
